Post by jon on Jul 28, 2022 23:39:02 GMT 1
Hi all,
We all know Yamaha don’t make a lot of the bits they sell in nice Yamaha boxes or bags.
It’s a consensus that things like LC petrol taps are identical to those sold directly by the manufacturer.
It’s also a common ‘to do’ to use genuine oils seals.
However what about those made by ARS? Surely the same part?
Opinions please.
Oil seals
Jul 29, 2022 8:13:51 GMT 1
via mobile
Post by liffy16 on Jul 29, 2022 8:13:51 GMT 1
Pretty sure yamaha 'sub out' seal manufacture to ars obviously made to yamaha spec as in all sub contract work to a major company,obviously yamaha cannot manufacture everything on site.
Post by geoffers997 on Jul 29, 2022 10:26:05 GMT 1
Post by chippy348 on Jul 29, 2022 10:44:37 GMT 1
Hi all, We all know Yamaha don’t make a lot of the bits they sell in nice Yamaha boxes or bags. It’s a consensus that things like LC petrol taps are identical to those sold directly by the manufacturer. It’s also a common ‘to do’ to use genuine oils seals. However what about those made by ARS? Surely the same part? Opinions please. Jon ARS- Yamaha same seal 100% the same no difference
Post by mak595 on Jul 31, 2022 7:06:40 GMT 1
Post by jon on Jul 31, 2022 7:08:24 GMT 1
Rip offs. ARX to sound like ARS. Jon
Post by tony2stroke on Jul 31, 2022 9:17:58 GMT 1
Rip offs. ARX to sound like ARS. Jon But they say for professional use so they must be OK
Post by jon on Jul 31, 2022 9:38:07 GMT 1
Rip offs. ARX to sound like ARS. Jon But they say for professional use so they must be OK Any professional would not use them, so I think they should say “not for professional use”. Jon
Post by Tobyjugs on Jul 31, 2022 11:38:16 GMT 1
A good ARS seal is very important when you go swimming
Post by chrisg on Jul 31, 2022 13:31:14 GMT 1
But they say for professional use so they must be OK Any professional would not use them, so I think they should say “not for professional use”. Jon Or "not for use in motorcycle engines" 😁 You pay your money and take your choice. If it doesnt concern you that you may have to strip your engine down to replace leaking crank seals then go for it. My view is that at the very least use ARS or Yamaha for the crank, all other seals can be replaced in situ, if needed. Simply Bearings sell good and cheap seals.
Post by 4l04ever on Aug 1, 2022 9:48:19 GMT 1
Rip offs. ARX to sound like ARS. Jon But they say for professional use so they must be OK "Professional" just means someone is charging you, not that they are skilled in any way...
Post by tony2stroke on Aug 1, 2022 11:12:22 GMT 1
But they say for professional use so they must be OK "Professional" just means someone is charging you, not that they are skilled in any way... It would seem that way today
Post by simon998 on Aug 2, 2022 8:44:08 GMT 1
Anyy recommendations on fork seals? I'd two sets rebuilt with seals the guy supplied last summer and they're both leaking already, I'm guessing he used chineseium.
Pyramid parts on ebay any good? I've a couple of tapered head bearings from them and they're grand
Post by lc350pete on Aug 2, 2022 9:32:47 GMT 1
Anyy recommendations on fork seals? I'd two sets rebuilt with seals the guy supplied last summer and they're both leaking already, I'm guessing he used chineseium. Pyramid parts on ebay any good? I've a couple of tapered head bearings from them and they're grand I got mine from Norbo they have been spot on one thing I did find that I was finding seals seals didn’t last as long as they should then I replaced the inner bush in the forks and they haven’t leaked since
Post by JonW on Aug 10, 2022 23:56:45 GMT 1
Pyramids bearings are not that great, a guy on a local forum here did a video with an all balls steering set and the pyramids were awful.
I would not recommend their seals either, defo cheap chinese.
Buy from yam or buy quality from you local bearing supplier. Dont chance it on things that matter. Kicker seals and stuff like that you can replace and get little use maybe, but not crank etc.
Post by mak595 on Aug 14, 2022 10:15:27 GMT 1
When i try and click on the rd250lc set , it just takes me to the blog, cant seam to get any details about them Trying to find out if the LC set are ARS...... EDIT - if you put them in your basket, you can then check out the description...Doesn't say make so i assume cheap copies
Post by dusty350 on Aug 14, 2022 10:18:11 GMT 1
Fowlers, Muttsnuts, Norbo, PJME, Madbiker all sell them, often from stock. Trusted suppliers of genuine seals Dusty
Post by mak595 on Aug 14, 2022 10:21:22 GMT 1
Fowlers, Muttsnuts, Norbo, PJME, Madbiker all sell them, often from stock. Trusted suppliers of genuine seals Dusty Paul has my crank atm so will get a set off him
Oil seals
Aug 14, 2022 10:58:40 GMT 1
via mobile
Post by vectisitch on Aug 14, 2022 10:58:40 GMT 1
Shoot me down if you want you bunch of tight arses. 🤪 These bikes are our passion. They are worth a load of pound notes. Why worry about saving a few quid on cheaper things like seals??? Buy genuine and not worry imo.
Incoming!!!!!!!! Run for the bunker..........
Post by tony2stroke on Aug 14, 2022 11:41:32 GMT 1
Shoot me down if you want you bunch of tight arses. 🤪 These bikes are our passion. They are worth a load of pound notes. Why worry about saving a few quid on cheaper things like seals??? Buy genuine and not worry imo. Incoming!!!!!!!! Run for the bunker.......... I totally agree with you on engine seals and all bearings, unless you know better, personally I prefer to use NTN bearings wherever I can, I have never had any issues with them in all my years of tinkering, I will also happily settle for Koyo or SKF, but NTN if possible for me, my preferences only. And I am not trying to say I know better, I think you can read all sorts into my statement, I am not the best at saying what I want to say on tinternet.
