Post by doohanno1 on Jul 24, 2022 8:48:51 GMT 1
Fitted a genuine throttle cable to the lc350 while i was fitting a beautifully refurbished oil pump...Trouble is i cannot get the adjustment to stop the pulley at the "B" mark ( Haynes )..It will go to the "A" and beyond.. Any thoughts on this...
Post by chrisg on Jul 24, 2022 10:12:12 GMT 1
I had exactly the same issue, but with a pattern cable.
Post by doohanno1 on Jul 24, 2022 10:15:00 GMT 1
The pattern one i took off lined up perfectly..🙄
Post by midlifecrisisrd on Jul 24, 2022 10:44:10 GMT 1
Is the cable under the end of the return spring in the pulley groove
If it is over it the cable will appear too short
Post by doohanno1 on Jul 24, 2022 11:25:28 GMT 1
I will certainly triple check that later on mlc... Cheers..
Post by doohanno1 on Jul 24, 2022 19:24:22 GMT 1
100% mlc...i obviously didn't "prod" the spring enough in fear of dislodging altogether.. Thanks again..
Post by midlifecrisisrd on Jul 24, 2022 19:30:33 GMT 1
Easily done
Glad it's an easy fix 👍
