merse2
Post by merse2 on Jul 11, 2022 12:36:10 GMT 1
Hi all. I have a 4L0 with standard pipes. The right hand pipe has split at a seam/weld almost around the entire circumference . The exhaust is in perfect condition apart from the split. Is Is weldable and if so, can anyone recommend someone near to me in Lincolnshire or someone that would accept and post via a courier? Gutted that my bike is off the road in this weather š
merse2
Post by merse2 on Jul 11, 2022 12:45:11 GMT 1
This is the split
Post by 4l04ever on Jul 11, 2022 12:58:13 GMT 1
Anything is fixable. It may show some battle scars, but would be reasonable after repair. Have you got tie bars fitted under your engine, as they are supposed to reduce the risk of cracking? Also, have you got pics of the flanges, as there are 3 types of exhausts, and the first type were prone to cracking on bikes without tie bars? Contact Chris (sidney81) on here, as he is an excellent welder in your neck of the woods. rdlccrazy.proboards.com/user/6695
merse2
Post by merse2 on Jul 11, 2022 13:14:25 GMT 1
Anything is fixable. It may show some battle scars, but would be reasonable after repair. Have you got tie bars fitted under your engine, as they are supposed to reduce the risk of cracking? Also, have you got pics of the flanges, as there are 3 types of exhausts, and the first type were prone to cracking on bikes without tie bars? Contact Chris (sidney81) on here, as he is an excellent welder in your neck of the woods. rdlccrazy.proboards.com/user/6695Thank you for the quick response and help. It is a non tie bar model so I suppose I should have expected it. This is the flange ...
Post by 4l04ever on Jul 11, 2022 13:19:57 GMT 1
The original 1980 exhausts have thin flanges and allow a fair bit of movement. Yamaha replaced them under warranty with the Blue dot (250) and Orange dot (350) thick flange exhausts to stop the cracking.
Post by Chewie01 on Jul 11, 2022 13:20:18 GMT 1
Sounds like a perfect excuse to get a set of expansion chambers on it
Post by 4l04ever on Jul 11, 2022 13:20:47 GMT 1
merse2
Post by merse2 on Jul 11, 2022 13:35:51 GMT 1
Sounds like a perfect excuse to get a set of expansion chambers on it I am in a very small minority but I just love the shape and colour of the original exhausts. I know a set of expansion Chambers make so much more sense but I really want to keep the originals.
Post by beardy on Jul 11, 2022 15:54:24 GMT 1
Iām with you on the standard pipes look and sound. But the weight difference and ease of taking expansions on and off with the sleeves and springs swung it for me
Post by zed1015 on Jul 11, 2022 17:14:37 GMT 1
Tig or Gas weld would sort that out no problems (It's only mild steel) . I'm in Linc's and would offer to do it but my Acetylene is on fumes and my usual "supplier" can't get any for the foreseeable..
Post by steeley on Jul 11, 2022 18:16:57 GMT 1
Hmmm , not good . I would clean the area up . Re align and get some tacks on with the mig then weld it up .
merse2
Post by merse2 on Jul 27, 2022 14:56:52 GMT 1
Just a quick update. Chris very kindly offered to weld the exhaust for me (and i am sure he would have done a perfect job) but I really wanted somewhere local. I used a place in Lincoln called Keweld and am really happy with the job they did. If anyone needed welding work doing in the Lincoln area, I can highly recommend them.
Post by steeley on Jul 27, 2022 20:25:15 GMT 1
Nice .
Post by Shytalk on Jul 28, 2022 9:31:08 GMT 1
Very tidy too.
Post by 4l04ever on Jul 29, 2022 10:37:22 GMT 1
Nice welding :-)
Post by shaunthe2nd on Jul 29, 2022 11:26:54 GMT 1
It lives! Well done, looks nice.
