Post by veg on May 31, 2022 18:59:13 GMT 1
Post by JMW on May 31, 2022 19:12:50 GMT 1
I bet she sounds nice
Post by Tobyjugs on May 31, 2022 19:32:47 GMT 1
I think piles might not be the only thing happening down below if you had to rely on the back brake .
Post by steve h on May 31, 2022 21:21:14 GMT 1
I think piles might not be the only thing happening down below if you had to rely on the back brake . Yes....great piece of engineering....sadly more ringpiece than just piece. Sort of says a lot about about the build.....
Post by JonW on Jun 1, 2022 0:10:28 GMT 1
When did he build that? Check out the mobile phone on the lift...
Post by midlifecrisisrd on Jun 1, 2022 8:47:21 GMT 1
When did he build that? Check out the mobile phone on the lift... If the 70 reg plate on the car is anything to go by it was at least late 2020 🤔 Steve
Post by JonW on Jun 1, 2022 9:06:26 GMT 1
When did he build that? Check out the mobile phone on the lift... If the 70 reg plate on the car is anything to go by it was at least late 2020 🤔 Steve wow... Did phones like that even work on the network then? Maybe its just a relic? lol
Post by veg on Jun 1, 2022 10:49:28 GMT 1
The state of the garage and work bench alone are enough to put me off. The seat looks like some orthopaedic cushion, in all too much cash for to little.
Post by steve h on Jun 1, 2022 21:50:28 GMT 1
The wiring is errrrmmmm interesting. Nice placement of the connector blocks tight up to the cyl head. But come to think about it......I've seen far worse wiring done by electricians... on many occasions. I would adorn the wiring with many a scotch lock connectors, keeping it up to the standard of the rear braking arrangement.
