hogie
Post by hogie on Mar 5, 2022 11:48:30 GMT 1
I did do a search on here before posting this but couldn't find what I wanted so forgive me if this has been asked a thousand times already but any tips for adjusting the pilot air screw on the r/h carb? I am struggling to do this in the garage so doing it roadside with a warm engine seems a real challenge. Is there any technique or special tool that may work well?
Post by shaunthe2nd on Mar 5, 2022 12:04:57 GMT 1
Buy a long reach screw driver. Even then it's a faff.
Post by stusco on Mar 5, 2022 12:47:27 GMT 1
My eye sight is the problem for me its usually out of the range of my reading glasses
Post by jessy03 on Mar 5, 2022 14:42:36 GMT 1
Flatten the end of a metal coat hanger, you can then bend it to suit works perfectly, not my idea I pinched off someone.
hogie
Post by hogie on Mar 5, 2022 15:23:09 GMT 1
Thanks guys, that's helpful. I did manage to check my base setting in the garage with a long thin screwdriver but didn't see that as a viable roadside tool in case I get stopped! I have plenty of spare coat hangers so will make a copy of Jessy's tool and give that a go. David
Post by sidney81 on Mar 6, 2022 7:43:20 GMT 1
I made a T handle screw driver from a bit of st st filler wire (Tig welding wire) flattened the end out ,bit like the coat hanger idea ! It's perfect it bends to ,I keep it under my seat on the air cooled 👍👍
Post by steeley on Mar 6, 2022 9:48:34 GMT 1
I made a T handle screw driver from a bit of st st filler wire (Tig welding wire) flattened the end out ,bit like the coat hanger idea ! It's perfect it bends to ,I keep it under my seat on the air cooled 👍👍 I made the same sort of thing out of some mild steel welding rod .
Post by 4l04ever on Mar 6, 2022 10:54:23 GMT 1
I have just got a long screwdriver :-)
