Post by 4l04ever on Jan 30, 2022 18:52:36 GMT 1
Will try to find some of the older pics out but this is the bike today. Will be ready to fire up very soon.
Post by 4l04ever on Jan 30, 2022 20:52:34 GMT 1
Before pic...
Post by 4l04ever on Feb 1, 2022 9:23:12 GMT 1
After finding and replacing a faulty CDI, it fired up after about 3 kicks
Post by Tobyjugs on Feb 1, 2022 9:32:15 GMT 1
Hi Rob, that looks like a Hi-Tech track bike!
Does it have exhaust sensors?
Post by 4l04ever on Feb 1, 2022 9:34:08 GMT 1
Yes. Type K thermocouples for measuring EGTs
Post by Tobyjugs on Feb 1, 2022 9:35:08 GMT 1
How did that work out?
Post by 4l04ever on Feb 1, 2022 9:36:29 GMT 1
Not much use, as the temperature can be low for good or bad reasons...
Post by 4l04ever on Feb 1, 2022 9:38:30 GMT 1
Probably more useful on a 4 cylinder engine as you can see which is the odd one out more easily. On a twin you are never sure if one is too high or the other too low.
Post by Tobyjugs on Feb 1, 2022 9:39:32 GMT 1
Thats roughly my thoughts as well. I think the operater has to be "Dialled" in to be able to read them correctly.
Post by 4l04ever on Feb 1, 2022 9:50:58 GMT 1
You can see your normal running temps, so you may notice it is hotter or colder than normal but what that means is difficult to identify.
Post by 4l04ever on Feb 1, 2022 22:51:01 GMT 1
Pic
Post by 4l04ever on Feb 1, 2022 22:58:10 GMT 1
Just replaced the water overflow pipe with a black one. Put the new fuel tap on and fitted new fuel lines and hose clips. Washed out the new tank and put in a gallon of Esso Super plus unleaded fuel premixed, as never use an oil pump.
Replaced a missing rubber seal on the fuel cap of the old tank....
Only a few minor parts to finish off.
I went to the post office yesterday and asked about putting this bike onto Historic Vehicle class. They said I needed to tax it, so I showed them my filled in V112 MOT exception form and gave them the V5. They said they would tax it on Historic Vehicle class from today :-) £0 Total
Post by 4l04ever on Feb 3, 2022 20:40:06 GMT 1
Fitted nice Nikko horns and fitted plugs in the EGT ports on the down pipes.
Post by 4l04ever on Feb 3, 2022 21:17:04 GMT 1
I suppose I should list the spec of this beast...
Blueprinted 4L0 cylinders, which have done around 1000 miles since they were rebored. Re-profiled head Siamese base gasket Squish set Engine leak down tested Rebuilt crank Modified shift star Modified stopper arm with bearing fitted EBC DRC043 Clutch kit fitted New Clutch bearing and output shaft bearing Gearbox checked, no chips on any gears Re-bushed kickstart idler gear Matching Primary gears Engine Casing blasted Side engine casings powder coated satin black Cylinder and head powder coated black Original 4L0 temperature sender fitted 31W carbs fitted Stator plate slotted further for more advance in combination with the Zeeltronic Ignition Ignition curve and fuelling setup on dyno Modified Clutch actuator arm to make clutch easier to pull Good original 4L0 radiator New Renntec chrome radiator grill Silicone radiator hoses Modified Airbox lid
31K forks and yokes Uprated custom springs fitted and preload set for me :-) Single 320mm front disk R6 blue spot front caliper with billet NK Racing adapter
Aftermarket adjustable levers Original Yamaha 4L0 Clutch cable.
Micron exhausts
This bike makes 48hp on a Dynapro dyno. A standard 4L0 makes around 38 to 40hp on this dyno.
Frame has been modified to UK spec for steering lock and has been powder coated. Swingarm has been shimmed correctly. YSS rear shock fitted.
Refurbished 4L0 standard wheels with machine marks still in the spokes. Good used BT45 front tyre. New BT46 rear tyre.
Good original tank and with new side panels and tail repainted by Mark Cordwell in "Blood Black" Mars bar colours. Locks all on one key
UK MPH Speedo, good rev counter, decent condition UK clock covers. Original OEM headlight and bowl fitted Stainless lifting handle fitted, but no centre stand.
Modified rear subframe, with narrower indicator bar moved underneath bracket to clear tail. Cut down number plate holder to fit slightly smaller number plate.
Good original loom with all standard OEM connectors in place.
Will be on Historic Tax.
I think that is most of it...
Post by donkeychomp on Feb 3, 2022 23:11:45 GMT 1
Cracking bike mate. Job well done I say.
Post by Mr Kipling on Feb 4, 2022 16:18:02 GMT 1
i echo the above remarks A+++...
Post by 4l04ever on Jun 27, 2022 19:35:59 GMT 1
Trying some different clothes on...
Post by JonW on Jun 28, 2022 1:01:03 GMT 1
looks good. Bright colours and the KR decals always seem to work well.
Post by 4l04ever on Jun 28, 2022 19:56:46 GMT 1
Just flushed out pink tank and transferred the fuel over. Came back and found these beauties. I feel like I am in an Allen Millyard video
Post by tony2stroke on Jun 28, 2022 23:27:47 GMT 1
Just flushed out pink tank and transferred the fuel over. Came back and found these beauties. I feel like I am in an Allen Millyard video There are 3 choky ones missing
Post by 4l04ever on Mar 13, 2023 8:51:21 GMT 1
Older pics with other colours...
Post by 4l04ever on Mar 13, 2023 8:55:48 GMT 1
Just adding a pic of the bike nearly ready to go to it's new owner. Yellow...
