Post by nomoreheros on Jan 28, 2022 11:43:57 GMT 1
Anyone have any experience with these keyster carb kits?... thinking of fitting em to my 31k carbs
Post by JonW on Jan 28, 2022 12:40:00 GMT 1
yes, its a No from us.
Post by Robbieben on Jan 28, 2022 14:21:25 GMT 1
Not very good in general, try Allens Performance for genuine parts.
Post by oldbritguy on Jan 28, 2022 14:29:17 GMT 1
Norbo and Mutts too. Use the search function on here for Keyster and read members views and personal experiences. Been there myself and eventually went for gen mikuni. Johnπ
Post by nomoreheros on Jan 29, 2022 12:13:30 GMT 1
Thanks for the comments guys...think I'll give keyster carb kits a miss... disappointing really as I used one of these kits on a ke175 and it worked a treat
Post by midlifecrisisrd on Jan 29, 2022 12:17:33 GMT 1
Think this is the issue
They have the spec of some kits right but the RD ones are wrong
The wrong taper on a needle and it will run like crap
Post by nomoreheros on Jan 29, 2022 12:46:38 GMT 1
What about the carb kits from Yambits?
Post by midlifecrisisrd on Jan 29, 2022 12:54:49 GMT 1
No experience of them, they may just be Keyster
What exactly is wrong with your carbs?
Jets don't wear out. Corrode maybe
Just buy the genuine bits you actually need
I've spent loads of time chasing a problem that I'm sure isn't carbs for it to turn out It's carbs
Fitting aftermarket parts just causes doubt when it doesn't run right
Post by JonW on Jan 30, 2022 0:53:21 GMT 1
+1
Steve is a Jedi Master.
Post by nomoreheros on Jan 30, 2022 11:00:11 GMT 1
I've been getting petrol coming out of the top pipe which I believe is a breather vent
Post by jessy03 on Jan 30, 2022 11:19:24 GMT 1
Iβd push that oil pipe on a bit further, or you might have a bigger issue. I have used the keyster kit before not the needles though, without issues, they were made in Japan though donβt know if that makes a difference Jess
Post by muttsnuts on Jan 30, 2022 11:39:16 GMT 1
if you get the right keyster kit for your carbs then they are ok-ish (see below), the problem is, alot of the kits covering a range/years of a bike, not accounting for the fact the carbs/jetting/configuration changed, so you need to know your carb spec before ordering a keyster kit or the likes
Yambits kits/parts are generally keyster kits, the needles and air screws are normally completely wrong, which causes allsorts of havoc
Petrol coming out of the bowl vent is the needle valve leaking, it might be the seat and needle, or it could be the carb body is worn and the O ring around the needle seat body is worn and petrol is getting past that way - I have some oversize O rings that take out some of that wear, I sent some to a forum member who was going to test them, I've used them on a few jobs and not had any issues yet
HTH
Post by midlifecrisisrd on Jan 30, 2022 11:50:16 GMT 1
+1 Steve is a Jedi Master. Too funny π Thanks for making me laugh, certainly brightened me up after my positive Covid test this morning π Steve
Post by 4l04ever on Jan 30, 2022 12:01:35 GMT 1
if you get the right keyster kit for your carbs then they are ok-ish (see below), the problem is, alot of the kits covering a range/years of a bike, not accounting for the fact the carbs/jetting/configuration changed, so you need to know your carb spec before ordering a keyster kit or the likes Yambits kits/parts are generally keyster kits, the needles and air screws are normally completely wrong, which causes allsorts of havoc Petrol coming out of the bowl vent is the needle valve leaking, it might be the seat and needle, or it could be the carb body is worn and the O ring around the needle seat body is worn and petrol is getting past that way - I have some oversize O rings that take out some of that wear, I sent some to a forum member who was going to test them, I've used them on a few jobs and not had any issues yet HTH The oversize o-rings sound worth a go, as the ones I have had in kits seem marginally too thin, so not making the best seal in the world.
Post by muttsnuts on Jan 30, 2022 12:06:05 GMT 1
I've got 2 oversizes, standard is approx 1.1mm, first one is 1.2mm and the other 1.35mm, doesn't sound much but its does make a difference
Post by muttsnuts on Jan 30, 2022 12:07:32 GMT 1
it was Steve (buck1963) I sent some to, not heard anything to say they didn't work, so can only assume they did !
Post by nomoreheros on Jan 30, 2022 12:18:41 GMT 1
I did notice when putting carbs back together that the brass body with the O ring were a lose fit
Post by JonW on Jan 30, 2022 12:41:49 GMT 1
+1 Steve is a Jedi Master. Too funny π Thanks for making me laugh, certainly brightened me up after my positive Covid test this morning π Steve Oh no, sorry to hear that m8!
Post by zig on Jan 30, 2022 14:24:05 GMT 1
Anyone have any experience with these keyster carb kits?... thinking of fitting em to my 31k carbs Norbo has all the individual bits you need for building your carbs in the link above for 'one stop shop' top of page ZiG
Post by Tobyjugs on Jan 30, 2022 14:29:23 GMT 1
+1 Steve is a Jedi Master. Too funny π Thanks for making me laugh, certainly brightened me up after my positive Covid test this morning π Steve Hmm does this coincide with receiving a milling machine?
Post by Tobyjugs on Jan 30, 2022 14:30:45 GMT 1
+1 Steve is a Jedi Master. Too funny π Thanks for making me laugh, certainly brightened me up after my positive Covid test this morning π Steve On a serious note i hope your not too badly affected by the covid.
Post by arrow on Jan 30, 2022 15:40:05 GMT 1
Iβd push that oil pipe on a bit further, or you might have a bigger issue. I have used the keyster kit before not the needles though, without issues, they were made in Japan though donβt know if that makes a difference Jess Jess is bang on there, plus it needs a retainer on it. All four of those pipe terminations must be the same; with retainers.
Post by nomoreheros on Jan 30, 2022 16:16:28 GMT 1
it was Steve (buck1963) I sent some to, not heard anything to say they didn't work, so can only assume they did ! Do you have any for sale?
Post by muttsnuts on Jan 30, 2022 16:43:47 GMT 1
Yes, I can send you a few, no problem
Post by steve h on Jan 30, 2022 17:07:00 GMT 1
+1 Steve is a Jedi Master. Too funny π Thanks for making me laugh, certainly brightened me up after my positive Covid test this morning π Steve Five days with pay... Yup...still catch it after 3 jabs, but hopefully now just a bad cold. Have a wee dram ..or three, with honey It's my remedy for most things...well when I say most things ...it was useless against cancer...but after a few I didn't give two **cks
Post by nomoreheros on Jan 30, 2022 17:39:28 GMT 1
Yes, I can send you a few, no problem Brilliant mate... I'll pm you... cheers buddy π
Post by midlifecrisisrd on Jan 30, 2022 17:56:59 GMT 1
Too funny π Thanks for making me laugh, certainly brightened me up after my positive Covid test this morning π Steve Five days with pay... Yup...still catch it after 3 jabs, but hopefully now just a bad cold. Have a wee dram ..or three, with honey It's my remedy for most things...well when I say most things ...it was useless against cancer...but after a few I didn't give two **cks Test and trace have said the 8th so 6 days π And that's only if I'm well enough to go back π No drams but I do have some very nice VSOP waiting π If it can at all be good news at least I'm not isolating stuck in my bedroom now as wife and son just tested positive too I'm used to the woman at the Chinese recognising me when I walk in but embarrassing when the guy at the PCR test site asks if I was there earlier π Steve
Post by 4l04ever on Jan 31, 2022 22:57:52 GMT 1
The Tourmax kits seem quite good. I have used a few of those without issue. I have upgraded a few of my LC 4L0 carbs to use the later Tourmax YPVS needle and seat sets, as I like the idea of the rubber tip on the needles.
