Post by jon on Dec 22, 2021 19:09:09 GMT 1
Hi all,
I know it’s been discussed before, but what are the current options for cable adjusters on PWK carbs with an LC throttle cable?
Norbo appears not to have any and Allen’s look too long. I’m tempted to make new lower cables and use the standard straight short ones.
Post by midlifecrisisrd on Dec 22, 2021 19:49:38 GMT 1
If the lc cable is too short have you looked at using a ypvs 29l cable?
Norbo does a good £30 pattern cable
The extra length may allow the use of the standard adjusters
Post by jessy03 on Dec 22, 2021 19:55:38 GMT 1
Hi Jon I’ve used some standard top adjusters, the Pwk top needs a few mods, done it a couple of times now. Jess (PS-I’ve not forgotten your kickstart gear👍)
Post by jon on Dec 22, 2021 20:00:42 GMT 1
Hi Jess,
Where did you get the adjusters from? Was it recently?
Post by jessy03 on Dec 22, 2021 20:08:16 GMT 1
Yes I recently got them off Norbo - 3 weeks ish ago
Post by abar121 on Dec 22, 2021 21:33:47 GMT 1
I got them from here, still in stock. Worked fine with the standard 31k cable. No mods at all. More slack would make it easier to fit the cable to the slides though. www.ebay.co.uk/itm/201506513499
Post by dusty350 on Dec 22, 2021 21:33:50 GMT 1
Hi Jon On the 400, I modded the standard 400 cable. The outer cable wouldn't fit into the Pwk brass adjusters because of the cable ferrules, so I removed the ferrules allowing the cable to fit fully inside the adjuster. But the inner cable still wouldn't allow the slides to sit right down, so I carefully cut back the outer metal spiral, meaning the outer cable was shorter and the inner cable was effectively longer, allowing fully closed to fully open movement on the slides; 20210228_140123 by dusty miller, on Flickr You can see on the bottom cable where I started to cut back the outer sheath. Dusty
Post by jon on Dec 22, 2021 22:07:30 GMT 1
Thanks for all the replies guys. Food for thought.
I’ll try Norbo first, but the website says out of stock.
I’m not adverse to making cables from scratch so that might need to be done.
Post by jon on Dec 23, 2021 19:19:17 GMT 1
Thanks Andy, I had see some like that in the past, but I don’t think they said they were genuine so I didn’t buy them. These do so I’ll take a chance and see what the quality is like. Jon
Post by headcoats on Dec 24, 2021 9:29:05 GMT 1
