Post by Deleted on Nov 24, 2021 9:03:03 GMT 1
Post by tonyd123 on Nov 24, 2021 9:24:29 GMT 1
It does say that the engine has suffered chain damage and it did go through the engine number, which has been re-stamped.
Post by Deleted on Nov 24, 2021 9:33:56 GMT 1
It does say that the engine has suffered chain damage and it did go through the engine number, which has been re-stamped. my mistake; not reading the add just looking at the pictures
Post by tonyd123 on Nov 24, 2021 9:35:06 GMT 1
It does also say "professionally" re-stamped, which is stretching it a bit
Post by midlifecrisisrd on Nov 24, 2021 9:41:44 GMT 1
It does also say "professionally" re-stamped, which is stretching it a bit Prostitution is a profession š¤£ Maybe he liked value for money "While your bent over love..." Steve
Post by 29davyt on Nov 24, 2021 9:57:13 GMT 1
Professionally Re-Stamped by a 4 year old by the look, wonder if he has pictures of the engine number before the chain damage occurred to back up his story ?
Post by fletche36 on Nov 24, 2021 19:28:59 GMT 1
To be fair its not a bad looking bike and i have seen worse go for(advertised) more.i would guess 7k would own it no problem. i bet there are plenty out there that have had a similar repair job done but i agree that the stamping could have been better.
Post by steve h on Nov 24, 2021 19:46:48 GMT 1
I would not spend any amount of money restoring/hybridising something with an engine number that looks like that. But to each their own. Maybe the chain went through the actual numbers. Such a shame. Be better off with non matching cases...by a long chalk Them numbers say seize me to plod..... I've worked with professionals of similar stature................
Post by oldbritguy on Nov 24, 2021 20:02:53 GMT 1
Irrespective of the circumstances around this particular engine I am becoming more of the opinion that Yamaha could have designed their engine cases a little stronger. Or have the numbers on the other side of the motor. Mmmm now where have I seen that before?š¤
Johnš
Post by veg on Nov 24, 2021 20:18:27 GMT 1
Or not design and sell a bike that appeals to knuckle dragging inept mechanically incompetent teenagers š
Post by reedpete on Nov 24, 2021 20:42:25 GMT 1
Got to remember it is ebayā¦the race track to the bottomā¦
Post by midlifecrisisrd on Nov 24, 2021 20:51:23 GMT 1
Irrespective of the circumstances around this particular engine I am becoming more of the opinion that Yamaha could have designed their engine cases a little stronger. Or have the numbers on the other side of the motor. Mmmm now where have I seen that before?š¤ Johnš Strangely Suzuki decided on the kettle to put the engine number above the clutch on the 72 kettle then moved it to above the chain for the next 5 years š Steve
Post by brg1200 on Nov 26, 2021 6:48:55 GMT 1
What is Soichiro Hona supposed to have said? ā I can engineer for speed, I can engineer for reliability, but I canāt engineeer for neglectā. Iāve had so many bikes with bloody chain damage. Iāve never had a chain snap, can only assume neglect!
Post by dusty350 on Nov 26, 2021 7:58:05 GMT 1
The last of the aircooled Rd's had the engine numbers on the clutch side; 20200525_155015 by dusty miller, on Flickr These engines share a lot of architecture with the Lc's and Pv's, so you do wonder why the engine number moved across to the other side ? Dusty
Post by Robbieben on Nov 26, 2021 8:16:45 GMT 1
What is Soichiro Hona supposed to have said? ā I can engineer for speed, I can engineer for reliability, but I canāt engineeer for neglectā. Iāve had so many bikes with bloody chain damage. Iāve never had a chain snap, can only assume neglect! I think a major factor years ago was an incorrectly fitted split link on the chain, lots of would be mechanics fitted them incorrectly and they would eventually come apart, not the chain itself failing just the failure of the link to stay together, thankfully not such a common occurence these days with soft link chains.
Post by veg on Nov 26, 2021 8:20:43 GMT 1
You have to remember that itās only the Uk and Japanese bikes with stamps on the left hand side the rest of the world was on the right hand side.
Post by abar121 on Nov 26, 2021 10:39:47 GMT 1
What is Soichiro Hona supposed to have said? ā I can engineer for speed, I can engineer for reliability, but I canāt engineeer for neglectā. Iāve had so many bikes with bloody chain damage. Iāve never had a chain snap, can only assume neglect! I think a major factor years ago was an incorrectly fitted split link on the chain, lots of would be mechanics fitted them incorrectly and they would eventually come apart, not the chain itself failing just the failure of the link to stay together, thankfully not such a common occurence these days with soft link chains. I had a new GSX600F that almost lost it's original chain. It was about half worn, heard a rumble from behind and not from me. A pin on one of the hard links walked almost completely out. Luckily it was caught in time and replaced. Bike chains used to be utter shite and stretch after a hard launch or two. Nothing like the good stuff we can get today, if you avoid the real cheapies.
Post by rigga on Nov 26, 2021 12:33:17 GMT 1
That's a fair bit of chain damage, normally wouldn't go into the stamped number area, unlucky, or lucky depending on your view.
Wouldn't touch it.
Post by Norbo on Nov 26, 2021 13:29:41 GMT 1
Its clearly broken of and been welded back on that has damaged the numbers so they have re done them . It wouldnt bother me .
Post by jon on Nov 26, 2021 18:13:50 GMT 1
Why on earth was that welded that way?
Surely the engine number section could have been welded from underneath without full penetration?
Funny how it would bother some people and not others. Iām in the āwould bother meā camp for what itās worth. Especially at that price.
Post by shaunthe2nd on Nov 26, 2021 19:29:46 GMT 1
Yes would bother me to a point I wouldn't buy. Shame as I think as a UK match no bike would be worth about Ā£2k more than advertised so seller taking a hit already.
Post by yamman1066 on Nov 26, 2021 21:05:45 GMT 1
it needs new cases
Post by headcoats on Nov 27, 2021 19:20:22 GMT 1
Post by midlifecrisisrd on Nov 27, 2021 19:58:46 GMT 1
This was the number on my LC that was stolen a few years back š¬
Post by andy748 on Nov 27, 2021 20:45:39 GMT 1
Personal choice isn't it, if there is photographic evidence great, but a non matching numbers LC/YPVS, the engine has a chance of being dodgy at some point, even with pristine numbers, i think we get too hung up on this type of thing, just my two penneth worth mind. Andy.
Post by rich on Nov 28, 2021 13:26:07 GMT 1
Then you'd get someone saying they aren't original, and would also have to be stamped anyway! Can't win really, doesn't look a bad bike at face value.
Post by yamman1066 on Nov 28, 2021 13:40:32 GMT 1
also has a ypvs engine cover on the right hand side
