Post by jon on Nov 20, 2021 16:51:52 GMT 1
Hi all,
I have a YPVS gearbox I aquired a while ago, and the teeth look to have lots of small horizontal marks. At first I thought it was wear, but it’s too uniform on each and every gear.
Starting to think this is how they looked with no wear after the machining/grinding?
I have also a worn 6th gear on an LC gearbox, and it is a completely different surface. Sort of very shiney, with the odd pit mark.
Anyone else noticed this on a very low miles gearbox? Certainly most I’ve seen don’t look like this.
Post by dusty350 on Nov 20, 2021 17:26:57 GMT 1
Post by midlifecrisisrd on Nov 20, 2021 18:18:05 GMT 1
The striping is normal
Worn ones are usually very shiney, discoloured or pitted just behind the mating surfaces
Post by Tobyjugs on Nov 20, 2021 18:40:47 GMT 1
Jon if you put it under a strong magnifying glass it very easy to see the differences.
Post by jon on Nov 21, 2021 12:22:58 GMT 1
The striping is normal Worn ones are usually very shiney, discoloured or pitted just behind the mating surfaces Steve Thanks everyone for the responses. As suspected I think the more the lines show the lower the wear if it’s factory machining/grinding marks. Might use this one then in my 385. Jon
Post by jon on Nov 21, 2021 12:24:02 GMT 1
Hi Dusty, Yes, my YPVS gearbox looks just like the top picture. Jon
Post by midlifecrisisrd on Nov 21, 2021 12:33:40 GMT 1
I've got some new banshee gears, I'll have to look and see what they are like
Post by jon on Jul 29, 2022 7:15:35 GMT 1
I've got some new banshee gears, I'll have to look and see what they are like Steve Waiting patiently Steve 😆 Jon
Post by Tobyjugs on Jul 29, 2022 10:30:03 GMT 1
It's a long way to his garage 😅
Post by midlifecrisisrd on Jul 29, 2022 17:25:00 GMT 1
It's a long way to his garage 😅 Currently 100 miles from it 😁 Steve
Post by yamman1066 on Jul 29, 2022 19:30:40 GMT 1
look ok to me
Post by geoffers997 on Jul 29, 2022 19:47:03 GMT 1
That’s one hoofing big backyard 🤣
