Post by midlifecrisisrd on Nov 13, 2021 15:30:26 GMT 1
Sent Dave a YPVS head with damaged domes Just got it back 😀 Domes recut, face skimmed, squish set to 1.2mm, and o ringed Water jacket will be sealed with silicone No more head gaskets, happy days Steve
Post by buck1963 on Nov 13, 2021 16:18:17 GMT 1
looks good!when you say the water jacket will be sealed with silicone ,are you just going to run a bead around it?I'm intrigued lol
Post by midlifecrisisrd on Nov 13, 2021 16:25:36 GMT 1
looks good!when you say the water jacket will be sealed with silicone ,are you just going to run a bead around it?I'm intrigued lol Yes, a thin smear around the water holes does it My 385 head is done the same way Steve
Post by midlifecrisisrd on Nov 13, 2021 16:28:03 GMT 1
My 385 head
Post by veg on Nov 13, 2021 16:48:41 GMT 1
Ahhh David of the dogs danglies a master craftsman of the highest order. A top job as usual. 👍
Post by dusty350 on Nov 13, 2021 16:51:59 GMT 1
Yes, a clever boy is our Mutts Nice job Dusty
Post by drc on Nov 13, 2021 17:07:09 GMT 1
Christmas comes early. Lovely job.
Post by Yogi on Nov 13, 2021 17:28:32 GMT 1
Looks a nice job as expected from Muttsey boy
Paying the old chap a visit myself 👍
Post by chrisg on Nov 13, 2021 20:00:12 GMT 1
Christmas comes early. Lovely job. That's exactly what I was going to write. Top job.
Post by tell7437 on Nov 13, 2021 21:57:35 GMT 1
Did Dave supply O rings with the head ?, I have a head that has been done but I need O rings.
Post by midlifecrisisrd on Nov 13, 2021 22:25:45 GMT 1
Did Dave supply O rings with the head ?, I have a head that has been done but I need O rings. Yes he supplied the rings From memory the 385 ones are Viton Just measure the ID of the groove and the width of the groove Plenty on eBay Or buy Fit in cord and glue up your own Steve
Post by donkeychomp on Nov 13, 2021 22:33:05 GMT 1
It's always a good day when something from Dave turns up!
Post by marrcel on Nov 13, 2021 23:13:11 GMT 1
How thick are your barrel gaskets ? And how do you torque the head up? I did the same as oem with my oringed head.
Post by midlifecrisisrd on Nov 13, 2021 23:15:29 GMT 1
How thick are your barrel gaskets ? And how do you torque the head up? I did the same as oem with my oringed head. I'll be using genuine base gaskets then torque the head as normal then do the barrel bolts Steve
Post by muttsnuts on Nov 14, 2021 13:08:26 GMT 1
head has been machined assuming stock base gaskets at 0.5mm thick (when compressed)
Post by muttsnuts on Nov 14, 2021 13:10:19 GMT 1
Did Dave supply O rings with the head ?, I have a head that has been done but I need O rings. yes I supply the O rings etc with the heads I do, but unless your head was done by me, it is most likely a different size, alot of companies use "imperial" O rings, I use metric ones, so you have to measure the ones you have, or the groove in the head to work out which size you need
