Post by rgbargey on Oct 28, 2021 8:54:49 GMT 1
Hi all
After a bit of advise, I’m wanting to fit a twin pull throttle and some 28mm Keihin carbs to my bike any one done this at all
Cheers in advance
Post by midlifecrisisrd on Oct 28, 2021 8:57:30 GMT 1
For 28mm carbs people usually use a modded standard cable
If you want twin cables look at something like a domino throttle
Post by rgbargey on Oct 28, 2021 9:50:45 GMT 1
Yes I was looking at the domino type when you say modified cable how did you mean ?
Post by midlifecrisisrd on Oct 28, 2021 10:32:27 GMT 1
The standard cable is for 26mm carbs so it will manage 28mm travel
Only slight problem is when using 45 degree elbows it is slightly short so slides don't quite close
Run an m6 x 1.0 die down the elbow another couple of mm or trim the outer or the adjuster and problem solved
Post by rgbargey on Oct 28, 2021 17:30:21 GMT 1
Nice one cheers
Post by chrisg on Oct 28, 2021 18:20:15 GMT 1
Hi all After a bit of advise, I’m wanting to fit a twin pull throttle and some 28mm Keihin carbs to my bike any one done this at all Cheers in advance I think the US datona 400 has twin throttle cables, maybe worth a look.
Post by bare on Nov 8, 2021 18:13:34 GMT 1
The standard cable is for 26mm carbs so it will manage 28mm travel Only slight problem is when using 45 degree elbows it is slightly short so slides don't quite close Run an m6 x 1.0 die down the elbow another couple of mm or trim the outer or the adjuster and problem solved Steve MY solution was to NOT use those metal angle tubes. Cables directly into the carbs (Smoother curve) Instant 'fix' and the cable friction is even less.
Post by rgbargey on Nov 22, 2021 23:03:00 GMT 1
So what your saying use standard length cable
Dave B
Post by Dave B on Nov 24, 2021 10:48:15 GMT 1
I found the throttle cable a little too short on my hybrid with handlebar raisers, so I took the junction box apart and made a new, 60mm longer cable to replace the front, single cable. I've had a lot of bikes for which you can't get a ready made cable, so I have the inner and outer cables and all the fittings already.
