Post by Dixie Dean on Oct 12, 2021 7:27:15 GMT 1
Hi guys anyone throw some light on this power valve engine hot but temperature gauge only showing just 5 to 10 mm off stop thanks.
Post by shaunthe2nd on Oct 12, 2021 9:40:43 GMT 1
Has the temp guage clock been refreshed with a new facia? If so, its likely someone has removed the needle and not replaced it to its original position. I recently rebuilt some LC2 kidney clocks and had to recalibrate the needle position by placing the sensor in water at different temperatures and monitoring/adjusting the needle position. If yours is a LC2 kidney unit then temp positions are as follows:
Post by Dixie Dean on Oct 12, 2021 11:17:10 GMT 1
I haven’t referbished the clocks but they were second hand (kidney)
Post by shaunthe2nd on Oct 12, 2021 11:36:57 GMT 1
I haven’t referbished the clocks but they were second hand (kidney) Probably one of the previous owners removed the needles and didn't recalibrate the position then.
Post by Dixie Dean on Oct 12, 2021 13:29:27 GMT 1
Ok thanks
Post by mak595 on Feb 5, 2022 19:26:10 GMT 1
Jumping on this thread, the temp gauge on my 31k used to work ok but now only just moves, tried 2 new temp sensors and no different, any idea's before i start ripping into it?
Post by Tobyjugs on Feb 5, 2022 21:58:08 GMT 1
Check you have a good earth between engine and frame.
