Post by vectisitch on Sept 28, 2021 10:17:31 GMT 1
So my powervalves are badly worn on the coupler ends and the coupler is worn too. To my mind this system is a weak point.
I know the gen yamaha ones have the rubber top for some movement but surely this causes the wear?? My thinking says that if you fit a solid billet coupler to stop any movement then the pv won't ever wear on those points? Why did Yamaha decide to add the rubber part? If the barrels are tightened down on the cases then there is no movement between the barrels and the pv's should move as one, the whole point of the coupler. My pv's were way out of sync and the bike felt nowhere near as powerful as i was expecting when i first rode it.
Post by headcoats on Sept 28, 2021 10:20:55 GMT 1
Great question, I would love to know the answer too !
lc2
Post by lc2 on Sept 28, 2021 12:14:44 GMT 1
It is possible to fit an Oldham coupling, I have done it previously and they allow for misalignment.
Post by JonW on Sept 28, 2021 13:40:19 GMT 1
Wicked made a billet PV coupling, it worked well. Dont know if they still do them.
The rubber part is there in case one set of PVs seizes i think.
Post by marrcel on Sept 28, 2021 14:53:05 GMT 1
I tried a solid connection but then one of the pv grinded. Some flex was needed with my setup. May yours not.
Post by andy748 on Sept 28, 2021 15:11:12 GMT 1
Post by badger1 on Sept 28, 2021 15:12:15 GMT 1
Post by vectisitch on Sept 28, 2021 15:42:46 GMT 1
I've got one from mb designs. I just wondered if my thinking was sound
Post by bare on Sept 29, 2021 2:53:11 GMT 1
Basic engineering practice.. Solid connections between two virbratory elements causes nothing but problems . When You design an engine... feel free to do what you wish.
