Post by donkeychomp on Sept 11, 2021 21:18:21 GMT 1
Just seen something on the A/C forum about throttle cables and I wonder if it might help us LC lot. We all know that pattern cables are useless but is this just down to a design flaw in the collector (the tube where all 3 cables meet)? If so perhaps a certain designer of 3D printed gizmos could come up with something...
Post by JonW on Sept 12, 2021 3:48:15 GMT 1
The AC cables are all seperate arent they with a collector that comes apart without destroying itself?
Post by jon on Sept 12, 2021 9:08:34 GMT 1
I thought it was the fact the oil pump cable was the wrong length?
Post by donkeychomp on Sept 12, 2021 21:16:50 GMT 1
Yes the collector comes apart and if it's the oil cable that's wrong then my idea has also come apart Alex
Post by bare on Sept 13, 2021 16:59:43 GMT 1
IF ?? willing to invest the time and effort. One Can DIY a MUCH better throttle cable assly. Than even OEM yama truth be told. Using the MUCH higher quality cables typically found in Bicycle shops. This can be a Very smooth almost frictionless Cable setup. Plus you can trim it to the Exact lengths your Bike needs. Reuse the Yama splitter .. If it's healthy it's not a problem item.
