Post by liffy16 on Aug 22, 2021 10:52:36 GMT 1
Going to bike meet last week my rd350ypvs N1 stopped in too gear running at about 7000rpm ,took plugs out no spark! After bike cooled down there was a weak spark, got her home and yesterday swapped coils from my lc it starts but doesn't sound right?and now when the ignition is turned on the powervalve doesn't do it's cleaning cycle? So could it be the cdi unit ?
Post by abar121 on Aug 22, 2021 10:58:03 GMT 1
It could be, or a bad earth?
What's the battery voltage? Is it charging?
Check and reseat the fuses and all connections.
Post by liffy16 on Aug 22, 2021 11:22:38 GMT 1
It could be, or a bad earth? What's the battery voltage? Is it charging? Check and reseat the fuses and all connections. Yea checked all connections fully charged battery even checked woodruff key on stator/crank
Post by abar121 on Aug 22, 2021 11:48:48 GMT 1
Check the resistance on the high / low windings and signal wires. Check and clean the stop switch.
If that's all ok, then it's probably the CDI unit I'd guess.
