Post by 3tj6 on Aug 17, 2021 19:56:24 GMT 1
A long time ago 1982, if my memory serves me i went to darley moor to watch bike racing for the first time , been into it ever since , the smell of castrol r was everywhere, can you still get it? Where from ? How much ? Can i put a tablespoon in my tank so i can get the smell ? Thanks Jon
Post by chrisg on Aug 17, 2021 21:37:13 GMT 1
A long time ago 1982, if my memory serves me i went to darley moor to watch bike racing for the first time , been into it ever since , the smell of castrol r was everywhere, can you still get it? Where from ? How much ? Can i put a tablespoon in my tank so i can get the smell ? Thanks Jon I have read that adding a small amount to the tank gives it the R smell. Not sure of quantities. I wonder if you can get castr R aftershave? 😆
Post by dougw on Aug 18, 2021 13:03:26 GMT 1
A long time ago 1982, if my memory serves me i went to darley moor to watch bike racing for the first time , been into it ever since , the smell of castrol r was everywhere, can you still get it? Where from ? How much ? Can i put a tablespoon in my tank so i can get the smell ? Thanks Jon I have read that adding a small amount to the tank gives it the R smell. Not sure of quantities. I wonder if you can get castr R aftershave? 😆 I chuck about a teaspoon of R40 into the lawnmower. Was told years ago that Castrol R and normal two stroke oil wouldn`t mix. Two weeks ago i put about 10ml of R40 and 10ml of Full synthetic 2 t in a small pot, still mixed nicely. This may change if you run the R mix through an engine, have heard that burnt R residue can turn acidic if left for a while, not good for engine internals on an infrequently used bike ? Put a drop in the LC tank when I knew it was going to do a lot of miles , and was getting a few tankful's of fresh super before it was parked up for any length of time.
Post by chequeredflagracing on Aug 18, 2021 14:22:25 GMT 1
Castor Oil (not Castrol) works for me. Egg cup full per fill up with petrol.
Post by chrisg on Aug 18, 2021 15:30:01 GMT 1
Castrol R and minerar/synthetic oil don't mix, but that's in a tank. Sure its OK if its in petrol
Post by dougw on Aug 18, 2021 17:48:47 GMT 1
Castrol R and minerar/synthetic oil don't mix, but that's in a tank. Sure its OK if its in petrol Exol full synth 2t and R40 mixing quite happily in a jar, but only two weeks into my test.
Post by dougw on Aug 18, 2021 17:51:17 GMT 1
The road racing boys have been using home brewed fuel mixes involving castor and mineral oil for years, but they do strip, clean and replace parts frequently.
Post by fletche36 on Aug 18, 2021 20:31:00 GMT 1
Ahh, i used to own a hilux that ran great on veg oil, anyway i once used a petrol can that had remnants of veg oil in ( virtually none) and used it to fill my ktm 300. it smelt great but gummed the rings so they stuck in the piston forcing a top end rebuild . ill not be risking it just for a nice smell.
Post by chrisg on Aug 18, 2021 22:57:00 GMT 1
Castrol R and minerar/synthetic oil don't mix, but that's in a tank. Sure its OK if its in petrol Exol full synth 2t and R40 mixing quite happily in a jar, but only two weeks into my test. Does it not separate into 2 levels of specific gravity?
Post by steve h on Aug 19, 2021 0:03:28 GMT 1
Post by JonW on Aug 19, 2021 1:20:37 GMT 1
Never understood the obsession with wanting to mess with the fuel mix of a bike that already you ride with two fingers over the clutch, but hey what do I know lol If you like the smell dont they do a candle? www.ebay.co.uk/itm/193770743309
Post by darboots on Aug 20, 2021 12:11:42 GMT 1
fabiostar
the older i get the faster i was.
Post by fabiostar on Aug 20, 2021 17:37:35 GMT 1
cant find R30 this last long time but iv been putting a small quantity of R40 into a full tank of petrol for about 400 years into all my bikes for the smell and not had a problem.
Post by rgbargey on Sept 7, 2021 22:32:25 GMT 1
Try Castrol A747 I run my trial bike and stilh saw on it going to run the yammagamma on it when complete smells good
Post by charles13 on Sept 8, 2021 10:23:21 GMT 1
I believe Blendzall makes a synthetic castor oil that smells just like the original and can be used in injector pumps
Post by phil5e0 on Sept 11, 2021 1:54:55 GMT 1
I have used Maxima Castor 927 in my enduro 2 strokes for the last 17 years. Never had a problem with it at 40:1 and it doesn't gum up the carb if you don't drain it if it's stood for a while. A word of warning though. Do not run it through the autolube system, it will have to be premix. Like the comments earlier, putting a bit in the tank should be ok as the castor and mineral oils will only mix in the carb just before combustion. Castrol R used to always separate from the fuel that's why we had to shake our bikes before we started them (I still do that now! Old habits). You can't beat the smell, I still get comments, especially from the old boys.
Post by beardy on Sept 11, 2021 11:01:19 GMT 1
Never understood the obsession with wanting to mess with the fuel mix of a bike that already you ride with two fingers over the clutch, but hey what do I know lol If you like the smell dont they do a candle? www.ebay.co.uk/itm/193770743309No need to understand it. Just enjoy the smell 👍🏻
Post by JonW on Sept 11, 2021 13:55:34 GMT 1
Never understood the obsession with wanting to mess with the fuel mix of a bike that already you ride with two fingers over the clutch, but hey what do I know lol If you like the smell dont they do a candle? www.ebay.co.uk/itm/193770743309No need to understand it. Just enjoy the smell 👍🏻 I just dont get that bit either.. but hey each to his own. You can get strawberry 2T oil as well Always amuses me that people 'put a bit in' their tanks, lowering the fuel content in the fuel air mix. Hope they upjet accordingly?
Post by dougw on Nov 10, 2021 14:35:13 GMT 1
Exol full synth 2t and R40 mixing quite happily in a jar, but only two weeks into my test. Does it not separate into 2 levels of specific gravity? Yes separated out, but stayed liquid, no apparent reaction between the two.
Post by Deleted on Nov 10, 2021 14:46:25 GMT 1
I have used Maxima Castor 927 in my enduro 2 strokes for the last 17 years. Never had a problem with it at 40:1 and it doesn't gum up the carb if you don't drain it if it's stood for a while. A word of warning though. Do not run it through the autolube system, it will have to be premix. Like the comments earlier, putting a bit in the tank should be ok as the castor and mineral oils will only mix in the carb just before combustion. Castrol R used to always separate from the fuel that's why we had to shake our bikes before we started them (I still do that now! Old habits). You can't beat the smell, I still get comments, especially from the old boys. how does pre-mix and injector two stroke oil differ ?
Post by Robbieben on Nov 10, 2021 17:34:20 GMT 1
I have used Maxima Castor 927 in my enduro 2 strokes for the last 17 years. Never had a problem with it at 40:1 and it doesn't gum up the carb if you don't drain it if it's stood for a while. A word of warning though. Do not run it through the autolube system, it will have to be premix. Like the comments earlier, putting a bit in the tank should be ok as the castor and mineral oils will only mix in the carb just before combustion. Castrol R used to always separate from the fuel that's why we had to shake our bikes before we started them (I still do that now! Old habits). You can't beat the smell, I still get comments, especially from the old boys. how does pre-mix and injector two stroke oil differ ? Premix oil is a slightly thicker heavier oil specifically designed to mix freely with fuel in a tank or a can, injector oil is thinner and easier for the pump to push to where it is needed, it still readily mixes with the fuel air mix. There are various trains of thought as to which is the better of the two methods, in race engines castor based oils are frequently used as castor oils provide higher lubricity than mineral oils however castor based oils require more engine maintenance to prevent rings gumming up and deposits forming inside the engine. The best for a roadgoing bike in modern times is the modern fully synthetic 2 stroke oils run through the oil pump. These provide the highest protection and lubricity for the money and are cleaner burning to protect the internals of engine and exhaust as well as the environment..(Did I just say environment)
