Post by Robbieben on Oct 18, 2021 14:02:58 GMT 1
I have a set of NC29 wheels and swing arm I'm hoping to use in my hybrid with K5 GSXR600 front forks. I hope my hybrid turns out as well as yours has, its looking very nice.
Rob123
Post by Rob123 on Oct 18, 2021 15:08:45 GMT 1
I have a set of NC29 wheels and swing arm I'm hoping to use in my hybrid with K5 GSXR600 front forks. I hope my hybrid turns out as well as yours has, its looking very nice. I'm sure it will Robbie π I do think you have to gamble a little on wheels, swingarm,forks,finishes,colour choices and hope it turns out well. That's why this is a great forum with plenty of info of what works and what doesn't. I spend hours reading through old posts picking up pointers and ideas I can use. This being my first hybrid build I couldn't of achieved anything like this without all the info contained in this site from bike builders past and present π
Rob123
Post by Rob123 on Oct 21, 2021 15:06:54 GMT 1
A few more bits bolted back on. Ive decided to keep the original indicators, headlight,footrests and clocks just to keep it abit more original looking. I've gone for headlight brackets that looked the closest to original I just need to drill a hole for indicator stalks. The inner mudguard was abit of a pain to get back on with it going around the shock I had to remove the swingarm then bolt the shock on to the Arm then push it through and back in place then bolt it all back up. There wasn't enough space to push the bolt through the bottom of the shock when the mudguard was around it.
Post by Yogi on Oct 21, 2021 15:27:20 GMT 1
Looking good Rob ππ
Rob123
42l Build
Oct 21, 2021 15:40:29 GMT 1
via mobile
Post by Rob123 on Oct 21, 2021 15:40:29 GMT 1
Looking good Rob ππ Thanks matt π
42l Build
Oct 22, 2021 6:17:10 GMT 1
via mobile
Post by sidney81 on Oct 22, 2021 6:17:10 GMT 1
Looking great ,I love this bit when things are going on ! I love the swing arm colour ? Is it Matt black or a gray ? ππ
Rob123
Post by Rob123 on Oct 22, 2021 8:07:38 GMT 1
Looking great ,I love this bit when things are going on ! I love the swing arm colour ? Is it Matt black or a gray ? ππ Hi Chris the swingarm is done in armor black it is matt black but does look abit grey against the gloss black frame. He did have a carbon black which is more grey. Cheers bud I'm happy with it although sometimes I think it looks like high temp exhaust paint π. Rob
Post by sidney81 on Oct 22, 2021 8:08:48 GMT 1
Looking great ,I love this bit when things are going on ! I love the swing arm colour ? Is it Matt black or a gray ? ππ Hi Chris the swingarm is done in armor black it is matt black but does look abit grey against the gloss black frame. He did have a carbon black which is more grey. Cheers bud I'm happy with it although sometimes I think it looks like high temp exhaust paint π. Rob Ha ha I like it I think it looks fantastic πππ
Rob123
Post by Rob123 on Oct 25, 2021 16:06:37 GMT 1
A few more bits bolted back on π Engine fitted and chain Front indicators I need to mount clocks but im still waiting on top yoke and I need to decide on the speedo. Footrests on
Post by Yogi on Oct 25, 2021 18:03:03 GMT 1
That mudguard as got to go π€
Other than that itβs looking good π
Rob123
42l Build
Oct 25, 2021 18:31:09 GMT 1
via mobile
Post by Rob123 on Oct 25, 2021 18:31:09 GMT 1
That mudguard as got to go π€ Other than that itβs looking good π Cheers matt π yer I'm not too keen on the mudguard either bulky looking isn't it. There isn't many options as far as I've looked other than to trim it down. Was thinking a carbon one but then think they look good colour coded. I've got a rear mudguard for rgv arm and think it looks too bulky aswell. Rob
Rob123
42l Build
Oct 25, 2021 19:12:11 GMT 1
via mobile
Post by Rob123 on Oct 25, 2021 19:12:11 GMT 1
Or did you mean the rear? π
Post by Yogi on Oct 25, 2021 19:20:35 GMT 1
Or did you mean the rear? π No mate the front looks good π Iβm on about the back it doesnβt follow the wheel lines It makes the wheel look too far back π
Post by Yogi on Oct 25, 2021 19:23:24 GMT 1
Only my opinion though itβs your bike
Iβd lose the back mudguard and make something from under the light
Your call mate π
Rob123
Post by Rob123 on Oct 25, 2021 19:35:23 GMT 1
Only my opinion though itβs your bike Iβd lose the back mudguard and make something from under the light Your call mate π I know what your saying matt it does look close to the back wheel. It maybe something I change in the future π I dislike the front more than the rear ππ
Post by andy748 on Oct 25, 2021 20:01:14 GMT 1
Post by evochris on Oct 26, 2021 11:34:52 GMT 1
great idea for the mudguard Andy, save the original from impending doom too.
Rob123
Post by Rob123 on Oct 29, 2021 19:48:31 GMT 1
Post by jessy03 on Oct 29, 2021 20:37:53 GMT 1
Looking very smart, keep up the good work
Jess
Rob123
42l Build
Oct 29, 2021 20:45:45 GMT 1
via mobile
Post by Rob123 on Oct 29, 2021 20:45:45 GMT 1
Looking very smart, keep up the good work Jess Thanks jessy will do π
Post by donkeychomp on Oct 29, 2021 21:12:07 GMT 1
That is brilliant. Looks like it was designed by Yamaha. And it's very discreet too. Great work!
Post by jessy03 on Oct 29, 2021 21:22:17 GMT 1
You might need a bigger radiator with the added capacity, be nice to keep the std rad guard though, one of the Chinese ones might do, think they are 10mm thicker.
Jess
Rob123
42l Build
Oct 29, 2021 21:27:20 GMT 1
via mobile
Post by Rob123 on Oct 29, 2021 21:27:20 GMT 1
That is brilliant. Looks like it was designed by Yamaha. And it's very discreet too. Great work! Alex Hi Alex it is a pinched idea π non the less it has turned out great cheersπ Rob
Post by sidney81 on Oct 29, 2021 21:34:00 GMT 1
Lovely bracket ,nice and neatly made ππ
Rob123
42l Build
Oct 29, 2021 21:34:09 GMT 1
via mobile
Post by Rob123 on Oct 29, 2021 21:34:09 GMT 1
You might need a bigger radiator with the added capacity, be nice to keep the std rad guard though, one of the Chinese ones might do, think they are 10mm thicker. Jess Hi jessy I have noticed everyone else putting on bigger rads its definitely in the back of my mind, ive got an uprated impeller I was going to try it as is to see we're its at then change it or add a fan if needed. I agree with keeping the cover if I can π Rob
Rob123
Post by Rob123 on Oct 29, 2021 21:36:33 GMT 1
Lovely bracket ,nice and neatly made ππ Cheers Chris it was a satisfying job to get done π
Post by sidney81 on Oct 29, 2021 21:37:29 GMT 1
Lovely bracket ,nice and neatly made ππ Cheers Chris it was a satisfying job to get done π Definitely , that master cylinder looks the part to π
Post by JonW on Oct 30, 2021 1:08:18 GMT 1
master cyl looks good. I used the OEM RGV version on mine (with Raask rearsets)
I agree the back end would look better with some kind of tail tidy and also that a bigger rad may be needed. You could plastic weld two covers together to keep the OEM look.
Post by Denzil on Nov 9, 2021 9:16:07 GMT 1
Just Awesome build and skills. Love the look at this beauty.
