Post by jon on Jul 25, 2021 13:02:44 GMT 1
Hi all,
I’ve used Bilthammer in the past to clean tanks with good success.
Consensus on here is it’s probably mainly citric acid which is much cheaper.
What concentration of citric acid to water have people been using?
Post by reedpete on Jul 25, 2021 15:19:17 GMT 1
Half a kilo in 25L is the sort of ratio you need. In truth it doesn’t matter too much but if you’ve not used before then yes, not a case of just a teaspoon of crystals to do a tank. Ultimately the amount of rust you are trying to convert determines how much you need.
Post by abar121 on Jul 25, 2021 15:24:31 GMT 1
Yep. A couple of cup fulls for a tank and leave it a few days. Heat helps, so put it somewhere warm.
Post by buck1963 on Jul 25, 2021 16:16:58 GMT 1
I used deox c to clean my f2 tank,left it overnight,like brand new inside
Post by Gunny on Jul 25, 2021 16:18:51 GMT 1
I used 16 bottles of white vinegar from Aldi 39p a bottle, left it for about 4 days worked a treat
Post by chrisg on Jul 25, 2021 18:11:54 GMT 1
I used deox c to clean my f2 tank,left it overnight,like brand new inside That stuff is brilliant, de rusts anything.
Post by steeley on Jul 25, 2021 19:36:04 GMT 1
Hi use about 10/20gms citric acid to a ltr of water .A mate of mine keeps the stuff warm with a fish tank heater. I have a blanking plate with a bit of inner tube to seal where the tap goes . For the fuel filler i put a rubber bung in that . I do the bottom first with 8.5 ltrs of mix in .Then i turn the tank over to do the top section . What i did find is you need to loosen the blanking plate to free the gas made from the mixture acting on the rust .
