Post by mintyfresh on Jul 4, 2021 10:10:48 GMT 1
Hi, my 1981 2fiddy LC has acquired a bigger hole in the rev range, just before the powerband. Say between 5 and 6 and a half. Flatter than a whitches tit. . . i have just taken the restictors the 4L2 exhaust and this was the result. more in the powerband, wiv less outta the powerband, especially around tht 5-6 range.
Post by oldelsieboy on Jul 4, 2021 12:05:48 GMT 1
Hi, my 1981 2fiddy LC has acquired a bigger hole in the rev range, just before the powerband. Say between 5 and 6 and a half. Flatter than a whitches tit. . . i have just taken the restictors the 4L2 exhaust and this was the result. more in the powerband, wiv less outta the powerband, especially around tht 5-6 range. Are you running 4L2 carbs, if so have you rejetted to OEM 4L1 settings? OEB
Post by mintyfresh on Jul 10, 2021 12:23:08 GMT 1
thanks m8. Yeah, the bikes a 4l2 german import. I have altered the main jet, from 170 to 190, not touched the pilot jets, even tho they are slightly bigger, 22.5 instead of the 4l1,s 20. This shouldnt have an affect the the midrange. I havent got super narrow screwdriver,to remove them, either. I have spent a day on the needle jet clip postion and its a better compromise on the third groove then the yam spec fourth. I also went down a tooth on the front spocket, 15 from 16. Its bang-tidy, now, considering my 15 stone 6,3 frame, lol. 95mph never felt so good.
Post by midlifecrisisrd on Jul 10, 2021 12:33:44 GMT 1
If you are running the 170 main instead of a 190 you will end up starting another thread about holing a piston ☹
Also your 22.5 being rich and 170 being lean is really going to mess up the transition from one to the other
Post by mintyfresh on Jul 10, 2021 13:05:48 GMT 1
Am running 190 main, 22.5 pilot, standard unrestricted 4l2 exhaust, standard airbox wiv snorkel removed. thanks steve.
fabiostar
the older i get the faster i was.
Post by fabiostar on Aug 2, 2021 22:13:17 GMT 1
Am running 190 main, 22.5 pilot, standard unrestricted 4l2 exhaust, standard airbox wiv snorkel removed. thanks steve. iv a german 250 that was the same when i fitted nikons. mines now 200 mains, standard pilots. one groove weaker on the clip and its running sweet as a nut.
