Post by alankelly on Jul 3, 2021 17:48:12 GMT 1
Hi all Quick question please Due to size constraints on my Tigcraft project (minimal room to squeeze in a rad) to solve the cooling issue (as want to keep a minimal naked look) thinking of changing the current motor from a liquid cooled engine (YPVS) to a air cooled motor Yes I know its a different approach (maybe an easier option to solving the rad issue) to solving a problem (and the frame will need some changes to accommodate finned heads etc) But the bike is unique in so many ways already so maybe an air cooled motor adds a twist to the whole build and keeps the minimalIstic look So my first question to all please is the following Are rd250 air cooled crank cases similar to RD250LC cases (mounts and overall general size) Once I know this I no doubt will have other questions and then maybe will be in the market for a aircooled motor if this change is feasible or just cases barrels and heads so I can see what changes are needed and then selling the YPVS motor Catch up soon and best wishes to all Al
Post by midlifecrisisrd on Jul 3, 2021 18:01:04 GMT 1
I'm sure all the mounts are different ☹
People put LC top ends on aircooled bottoms so I suppose it mist be possible to put an aircooled top end on an LC bottom
Post by midlifecrisisrd on Jul 3, 2021 18:02:08 GMT 1
It's just a pity it wouldn't have the power to fully appreciate that chassis
Post by alankelly on Jul 3, 2021 18:07:59 GMT 1
Yes I know but the rad issue is a real headache
I think when you dig into the history of the frame I have I believe it was built for the original owner for super mono racing ( I think with an air cooled single ) hence the lack of space around the engine
And to be honest just want to finish it to a high standard with that naked look and I think an air-cooled motor would look the biz even if the. Chassis outmatches the engine performance
Also harder to get but may try to find a rd400 motor if it looks like this may be an option also?
Post by alankelly on Jul 3, 2021 18:12:25 GMT 1
I'm sure all the mounts are different ☹ People put LC top ends on aircooled bottoms so I suppose it mist be possible to put an aircooled top end on an LC bottom Steve Well that sounds promising I wonder if rd400 barrels fit LC cases Trouble is I don’t know enough about all the different engine types but should be plenty of good advice on here Best wishes Al
Post by muttsnuts on Jul 3, 2021 18:19:39 GMT 1
RD400 is 62mm stroke, so no you can't fit 400 barrels on an LC bottom end as its only 54mm stroke.
The LC crank cases should take the 250 air cooled top end though, stud patterns are identical and the stroke is the same and you could use the LC pistons etc, then the only thing to check/adjust would be the port timing if its slightly different
HTH
Post by midlifecrisisrd on Jul 3, 2021 18:49:29 GMT 1
Nah, +7mm crank in LC cases and 1mm off the bottom of 400 barrels 🤣
Post by steve h on Jul 3, 2021 19:09:28 GMT 1
Air cooled? I wonder if anyone has ever used Phazer snowmobile cyls? R by Ernest Stoppage, on Flickr
Post by dusty350 on Jul 3, 2021 19:41:05 GMT 1
Can you not use 350 aircooled barrels as guys bolt them onto aircooled 250's. I'm no expert on smaller aircooled stuff so maybe not ?? Width of the fins is gonna be an issue with what you have at the mo. You are going to need 11 inches minimum, internally between the subframe down tubes to clear the barrels. Front mount will be in roughly the right place, but the aircooled cases have a much wider casting at the front and use 2 long bolts, but you could just use the 1 top bolt - that's what I did on the Cafe bike. I dont think the mounts will be the issue, more likely the width of the top end. I would post pics but my Flikr account has gone belly up since I changed internet provider on Thursday, but as soon as I recover the account I will post pics of the aircooled mounts. Failing that, look in my build threads as there are lots of pics in there And, 400 motors are VERY thin on the ground Dusty
Post by 3tj6 on Jul 3, 2021 20:54:04 GMT 1
Can you put 2 rads on the leading edges of the frame, 1 each side like some moto cross bikes do , didn’t the sp1 Honda have rads round the side too?
Post by alankelly on Jul 3, 2021 21:09:06 GMT 1
Can you not use 350 aircooled barrels as guys bolt them onto aircooled 250's. I'm no expert on smaller aircooled stuff so maybe not ?? Width of the fins is gonna be an issue with what you have at the mo. You are going to need 11 inches minimum, internally between the subframe down tubes to clear the barrels. Front mount will be in roughly the right place, but the aircooled cases have a much wider casting at the front and use 2 long bolts, but you could just use the 1 top bolt - that's what I did on the Cafe bike. I dont think the mounts will be the issue, more likely the width of the top end. I would post pics but my Flikr account has gone belly up since I changed internet provider on Thursday, but as soon as I recover the account I will post pics of the aircooled mounts. Failing that, look in my build threads as there are lots of pics in there And, 400 motors are VERY thin on the ground Dusty Hi Dusty Just checked frame and I have 9” at the moment so a bit of frame modifications if I source an air cooled twin cylinder motor but much easier than trying to find a rad position I need to now sit down and do some thinking and then crack on with a possible plan but definitely want to now go the air cooled route with either a twin or large single as some others have suggested Catch up soon Best wishes Al
Post by donkeychomp on Jul 3, 2021 21:11:13 GMT 1
I just might have an RD250 engine... Alex
Post by midlifecrisisrd on Jul 3, 2021 21:21:45 GMT 1
Now if you could find an IT490 engine 🍆
Post by alankelly on Jul 3, 2021 21:23:51 GMT 1
Yes somebody else mentioned this 😁
Google it and it looks like a single cylinder motor but know nothing about them
Would this be another option??
Post by midlifecrisisrd on Jul 3, 2021 21:39:22 GMT 1
A single would fit easier
IT490 was only 35hp but it was a torque monster
And aircooled big 80's crosser engine would do
Post by midlifecrisisrd on Jul 3, 2021 21:57:13 GMT 1
YZ490 was 55 hp 😱
Post by alankelly on Jul 3, 2021 22:04:55 GMT 1
Yes had a look and found a couple on the web Not cheap but it smokes😁 Certainty another option
Post by alankelly on Jul 3, 2021 22:24:05 GMT 1
Plus single cylinder would make exhaust routing easier too
Like I said earlier I think frame was built by the original owner to race single cylinder, and somebody has pointed out it may have been made to race in the sound of singles racing series in the nineties but never made it into the track so it’s looking more like I may go the single cylinder route but still want to explore if possible if I could fit an air cooled twin first.
At least I have a PV engine to fund the possible motor change😁
Many thanks for all the suggestions and advice so far
Best wishes Al
Post by reedpete on Jul 3, 2021 23:04:29 GMT 1
Al, If it helped, I have a few aircooled lumps you could use to check fitment and I'm only up the road from you so feel free to come up with tape measure and or borrow stuff. I’m very familiar with all the twin air cooled motors, and TZR for that matter. The easiest fix would probably be LC bottom end as the engine mounts are same as YPVS and 350 Aircooled top end as the barrels are narrower and shorter than the 400.
Post by andy748 on Jul 3, 2021 23:41:28 GMT 1
It might be an out there suggestion Al, but a LC Chinese ally rad on the front forks, like an early YZ with a mesh shroud and number board, braided hoses and limited lock stops, never seen it done but we're all a bit crazy enough to try it on this forum??? Andy.
Post by midlifecrisisrd on Jul 3, 2021 23:45:28 GMT 1
I'd thought that too
If you mount a frame to the headstock like a fairing mount and fit a rad to it so it is fixed
Spray the fins white then black for a number 😀
Post by midlifecrisisrd on Jul 3, 2021 23:46:18 GMT 1
Like an oilcooler on the old gsxr street fighters
Post by 4l04ever on Jul 4, 2021 0:03:44 GMT 1
A 2MA TZR250 engine might be a good option too, as they are smaller and shorter...
Post by 4l04ever on Jul 4, 2021 0:05:13 GMT 1
I think aircooled cylinders would be a lot wider than LC/YPVS due to the fins...
Post by JonW on Jul 4, 2021 0:35:29 GMT 1
As has been said above, Id look at a rads either side, ie like dirt bikes. Its not a perfect solution, but you only need 750ml of capacity and i think some KTM units will reach that.
As for singles, KTM 380? Im sure some guys raced supermono with something like those motors?
Post by reedpete on Jul 4, 2021 10:09:16 GMT 1
To get early narrow 350cc AC barrels to work you really need 5mm extra of clearance each side on current setup between that YPVS head and your cradle tubes . The 11” dusty’s talking about would be required for later engines including all 400cc which basically had one extra fin on the head. No doubt 2MA would be an easier install but I think the end result might seem a bit like reinventing the wheel as both R1Z (trellis frame) and 2MA and 3MA delta box chassis are fairly sorted right out of the box.
Post by markhoopy on Jul 4, 2021 11:01:12 GMT 1
I think Alan should add the photo of him sat on the bike to this thread just so everyone can see how tiny it is. The IT465/490 engines are very hard to come by but would certainly be a good option, as would PE400 etc. How come nobody has suggested a Maico 490 engine yet?
Post by alankelly on Jul 4, 2021 11:10:22 GMT 1
Ok just so you can see the size of the bike here is a is a picture of me on the project once I got it to a roller Also I am 5ft 8” Here is another piccy that shows its size It funny when you are sat on it it’s really comfy and you feel like you are in it rather than on it if that make sense Really starting to think large air cooled single here due to frame size ? Please keep the suggestions coming Best wishes Al
Post by muttsnuts on Jul 4, 2021 11:21:14 GMT 1
what about something like a RS/RGV250 engine, they are relatively small, light and can be made to kick out very good power if modified to 300/325cc etc and would probably leave enough room to get a rad fitted
I am assuming the limiting factor here is how far back you can take the motor due to the swinging arm pivot point, which needs to align (give or take) with the front sprocket centre line
A big single would work for sure, but surely that might even mean you have enough space to get a radiator in ?
I have custom radiators made, granted they aren't cheap, but they are made to fit in the space available and have been fitted to ensure sufficent cooling, some are double width/stacked rads, others curved, some split with join pipes, anything is possible within reason, clearly that does cost money though, so is a budget issue as well
Post by markhoopy on Jul 4, 2021 11:48:52 GMT 1
Here is another piccy that shows its size It funny when you are sat on it it’s really comfy and you feel like you are in it rather than on it if that make sense Any engine that produces a big amount of power or torque would make that a hard bike to ride.
