Post by muttsnuts on Jun 28, 2021 14:14:12 GMT 1
Ok 125 guru's, got my hands on a 2RH CDI (TZR125) which I am told works fine on the MK3 (YPVS) 125LC
I've wired it how I think it should be;
RD125LC TZR125 wires Brown to brown (switched live) Orange to orange (coil wire) Black to black (earth) Yellow to Yellow (?) --> to YPVS controller Black/Red to red/black (?) --> to YPVS controller Black/white to black/white (kill switch) White/green to white/green (pickup) White/red to white/red (pickup)
---- black/yellow - RPM/tacho feed (not used for RD125LC
I am not getting a spark, so I've tried swapping the pickup wires up, but still nothing, what am I missing ?
Any ideas, or is the 2RH CDI I got duff (despite being told its good ?)
Thanks in advance
Robbieben
Member is Online
Post by Robbieben on Jun 28, 2021 17:02:49 GMT 1
Ok 125 guru's, got my hands on a 2RH CDI (TZR125) which I am told works fine on the MK3 (YPVS) 125LC I've wired it how I think it should be; RD125LC TZR125 wires Brown to brown (switched live) Orange to orange (coil wire) Black to black (earth) Yellow to Yellow (?) --> to YPVS controller Black/Red to red/black (?) --> to YPVS controller Black/white to black/white (kill switch) White/green to white/green (pickup) White/red to white/red (pickup) ---- black/yellow - RPM/tacho feed (not used for RD125LC I am not getting a spark, so I've tried swapping the pickup wires up, but still nothing, what am I missing ? Any ideas, or is the 2RH CDI I got duff (despite being told its good ?) Thanks in advance TZR125 87 2RH wiring is Black = Earth Black/White = B/W Kill Switch Orange = Coil Black/Yellow = Black/Yellow on YPVS Controller, not always on UK models. Green/White = Green/White Magneto Red/White = Red/White Magneto Brown = Brown Magneto Black = Black Magneto Yellow = Yellow Magneto Red/Black = Red/Black Magneto TZR125-Wiring-Diagram-1 by Rob Bennett, on Flickr
Post by muttsnuts on Jun 28, 2021 21:37:28 GMT 1
cheers Rob, think the CDI unit I got is iffy, so back to square one unfortunately
Post by museumman on Oct 3, 2021 16:04:30 GMT 1
cheers Rob, think the CDI unit I got is iffy, so back to square one unfortunately How come you're not sticking with Ignitech's Dave? or is this for a cheaper job for someone? I was selling an import with no papers and knew I wouldn't get the right money for it, I was reluctant to provide it with an Ignitech, so tried the TZR CDi and never got a spark either. I'd confidently soldered on an RD plug with nice colour matched shrink tubing as well In the end I used an Ignitech and will use that as a selling point when the time comes. BTW not that it's a big deal, the TZR seems to have a different curve, it's the same shape but lower advance throughout. There's a guy on Facebook who tried to corner the market for TZR CDis years ago to use on RDs, pretends to be an RD expert and tuner but is a complete embarrassment, he was recommending them of course but also giving out a lot of bad advice causing people problems and massive time waste. The RD loom has Red wire /black stripe kill switch and the black wire/white stripe is to the ypvs control box.
Post by muttsnuts on Oct 3, 2021 18:30:58 GMT 1
cheers Rob, think the CDI unit I got is iffy, so back to square one unfortunately How come you're not sticking with Ignitech's Dave? or is this for a cheaper job for someone? I was selling an import with no papers and knew I wouldn't get the right money for it, I was reluctant to provide it with an Ignitech, so tried the TZR CDi and never got a spark either. I'd confidently soldered on an RD plug with nice colour matched shrink tubing as well In the end I used an Ignitech and will use that as a selling point when the time comes. BTW not that it's a big deal, the TZR seems to have a different curve, it's the same shape but lower advance throughout. There's a guy on Facebook who tried to corner the market for TZR CDis years ago to use on RDs, pretends to be an RD expert and tuner but is a complete embarrassment, he was recommending them of course but also giving out a lot of bad advice causing people problems and massive time waste. The RD loom has Red wire /black stripe kill switch and the black wire/white stripe is to the ypvs control box. I did end up fitting an ignitech, I was loaned a good CDI, the bike ran 11.9bhp as was, I fitted the ignitech ands it ran 18bhp straight off after a quick map set up, so going forward it will be an ignitech everytime if I get a MK3 in with a dodgy CDI I threw the TZR125 CDI in the bin, couldn't get it to spark etc, not sure if it was faulty or the info wasn't correct
Post by simon998 on Oct 4, 2021 12:26:04 GMT 1
I'm running a 2RH CDI, MK3 rd125lc loom, 10w engine/stator. II was told it would never work, but a bit of trail and error and I got it working. There's a load of unconnected connector blocks and bullets but it runs the very best. Do you supply (or can you) expansions for the rd125lc yet muttsnuts
