Post by mak595 on Jun 26, 2021 17:42:55 GMT 1
What do the guru's think of this?
I've rebuilt the motor, its a new mikita basket, plates etc. bike runs ok but bit concerned that the basket seems to be off centre, obviously I would never know if I didn't have a clear window 🤣
Put the vid on fb, some people say it's fine, others don't 🤔🤔
Post by stusco on Jun 26, 2021 17:55:22 GMT 1
The shaft looks alright do you think its the cast pressure plate maybe an optical illusion
Post by 29davyt on Jun 26, 2021 18:06:27 GMT 1
Spray that cover black then it will all be fine 😂
Post by Tobyjugs on Jun 26, 2021 18:35:01 GMT 1
There's nothing on the end of this type of clutch to keep it true. I would just go with it.
By the way I love the colour of those pipes. What are they?
Post by mak595 on Jun 26, 2021 18:47:12 GMT 1
There's nothing on the end of this type of clutch to keep it true. I would just go with it. By the way I love the colour of those pipes. What are they? Muttsnuts, mild steel pipes that I sprayed in VHT lacquer, turning quite a nice shade now ![](https://uploads.tapatalk-cdn.com/20210626/80f82a804adeb5940a266044a0f79880.jpg)
Post by Tobyjugs on Jun 26, 2021 18:52:16 GMT 1
What a beauty. I love mild steel pipes when they go golden brown. In my eyes that the real deal.
Post by mak595 on Jun 27, 2021 5:46:27 GMT 1
So, do we think its just the pressure plate bolted up slightly pissed?
Post by brigitte on Jun 27, 2021 9:58:31 GMT 1
Hello,
the pressure plate is held in position by the teeth of the clutch hub. It must be able to move and so it may be a little off center. The screws only push the springs against the assembly, so there is nothing you can do.
I second the advice to paint the window: The more you know, the more you get worried.
Post by chrisg on Jun 28, 2021 14:54:23 GMT 1
Hello, the pressure plate is held in position by the teeth of the clutch hub. It must be able to move and so it may be a little off center. The screws only push the springs against the assembly, so there is nothing you can do. I second the advice to paint the window: The more you know, the more you get worried. Very true. If it was way out you would get a lot of vibration. I first thought that it may be an optical illusion.
Post by steve h on Jun 28, 2021 15:58:16 GMT 1
Just an outside the box thought... but does it look worse in the vid as against seeing it with your eyes? The shutter speed distorting things.
Post by mak595 on Jun 28, 2021 18:21:59 GMT 1
Just an outside the box thought... but does it look worse in the vid as against seeing it with your eyes? The shutter speed distorting things. Its about the same tbh
Post by rigga on Jun 28, 2021 20:02:33 GMT 1
Not sure if you can see but don't think mine runs like yours .....has a lock up on top of the pressure plate, so maybe harder to see properly
Post by JonW on Jun 29, 2021 1:36:59 GMT 1
Silly thought... the OEM style plates are meant to be offset as you fit them, using the small arrow marks. You didnt put all of them in the same way did you? Maybe that would have too much 'weight' in one area?
Post by Tobyjugs on Jun 29, 2021 18:23:24 GMT 1
Silly thought... the OEM style plates are meant to be offset as you fit them, using the small arrow marks. You didnt put all of them in the same way did you? Maybe that would have too much 'weight' in one area? Great thought!
Post by mak595 on Jun 30, 2021 20:29:16 GMT 1
No, all set at different offsets....
Post by 4l04ever on Jul 1, 2021 17:47:13 GMT 1
Can you see the outer basket, as that would indicate if the whole basket is affected, or just the inner part... ![???](//storage.proboards.com/forum/images/smiley/huh.png)
Post by mak595 on Jul 2, 2021 19:56:42 GMT 1
Can you see the outer basket, as that would indicate if the whole basket is affected, or just the inner part... ![???](//storage.proboards.com/forum/images/smiley/huh.png) Not 100% sure but as the basket is new as well as the bearings, im assuming thats ok, on night shifts atm, after the weekend I'm gonna take the clear window off and loosen the spring bolts to see if there is any movement on the pressure plate...
Post by tsa on Jul 3, 2021 9:46:39 GMT 1
Can you see the outer basket, as that would indicate if the whole basket is affected, or just the inner part... ![???](//storage.proboards.com/forum/images/smiley/huh.png) Not 100% sure but as the basket is new as well as the bearings, im assuming thats ok, on night shifts atm, after the weekend I'm gonna take the clear window off and loosen the spring bolts to see if there is any movement on the pressure plate... Kenny Being new doesnt mean the basket couldnt have been machined wrongly or the primary gear isnt centred.
