Post by headcoats on Jun 26, 2021 8:37:19 GMT 1
Having a right job finding the shim,sleeves and spacers to get the VJ22 swingarm in the LC
I can get the dust caps and needle bearings but there are quite a few more bits
Is there other parts off other bikes that can be used and are more freely available
Post by dusty350 on Jun 26, 2021 9:26:24 GMT 1
Have you cross referenced part numbers with the Vj21 swingarm ? Easily done on Fowlers website Dusty
Post by headcoats on Jun 26, 2021 9:39:25 GMT 1
Think some of the bits are obsolete now Remember NK do the reducers so the LC spindle fits Then there are the large washers on the ends that butt up against swingarm but have a big enough hole so the sleeves fit through
Post by midlifecrisisrd on Jun 26, 2021 11:36:47 GMT 1
You don't use the washers on a ypvs so are you sure you need them
End caps available from Suzuki
Check Wemoto for roller bearings
Just get the rescuers from NK or get someone with a lathe to knock a set up
Post by midlifecrisisrd on Jun 26, 2021 11:38:12 GMT 1
Also is it not possible to use an LC sleeve and get bronze bushes made to adapt the swinger
