Post by neilrowe on May 3, 2021 13:33:52 GMT 1
Hi Chaps
I have a set of TM30 flatsides I am considering fitting to a 4L0. Has anyone got a baseline jetting for this? Would be helpful - much easier to start in the general ballpark, as most will appreciate.
Thanks
Post by rich on May 3, 2021 16:56:16 GMT 1
Hi, nope sorry no such thing as a ballpark setting. The jetting will depend on so many factors - whether you are running airbox or filters, which pipes, state of tune, premix or oil pump etc etc!! Need more info
Post by Norbo on May 4, 2021 8:14:11 GMT 1
There is no starting point with carbs as every set are different and every bike is different . for example a pwk 28 may work with 130 main jet but a round slid VM mic carb would need a 240 and the mic flat sides being a more modern carb may be some were in between like a 200 or 210 . you just need to fit them take it for a ride not a thrash and see how it feels and adjust according
Post by neilrowe on May 4, 2021 11:32:57 GMT 1
Thanks guys - reason I asked is that HVCycle advertise TM carbs on their USA website. They give details of the jettting they recommend for a std LC (yes, I know the 4L0 was not imported). They do not list a TM30 though.
Was hoping somebody had fitted these and could assist..
As Norbo says, the other way is to fit, start, ride and start buying jets:-)
FI:
Bike has been bored 2.25mm os Squish: 1.2mm Combustion chamber has been sized to yield a CR of 7.3:1 Exhaust port has been raised to 28mm Running locally made spannies Zeeltronic I have "ported" the reed block as per Ed Ehrlenbach recommendations Carbon fibre reeds 6mm reed spacer Timing set at 1.85mm Currently running std VM26 carbs (01 type). 27.5pj, clip 2 nothces from top, 240mj
bike has a flat spot at about 5500rpm which i am struggling to eliminate with jetting. Read somewhere that the flatsides flowed much better and helped with eliminating any mid range flatspots.
I have a couple of sets of VForce3 reedblocks on order too.
smoke
Post by smoke on Nov 2, 2021 13:37:57 GMT 1
Post by neilrowe on Nov 5, 2021 10:19:13 GMT 1
Some further updates for info:
1. I fitted a UFO flow optimizer to each VM26 (have not fitted the flatsides) 2. V Force 3 reed blocks installed with a 10mm spacer 3. Currently running 270 mj's
No more flat spots and the thing takes off like a rocket at 8000 rpm upwards (local spannnies and raised exhaust port have shifted the powerband upwards). Revs to 11000 in a flash once on the pipe. Bike is seriously quick now and a blast to ride.
Bottom line - perseverance.
As a side note: I purchased a set of pin gauges to accurately check my jets. It is amazing to see the variance in numbered jet sizes. A new Mikuni 240 is smaller than a well used one, for example.
Also two new jets with the same designated marking can vary considerably.
