jam911
Post by jam911 on Apr 29, 2021 18:51:14 GMT 1
Do I have to rivet the rear reflector bracket on to the mudguard or can I bolt it?
Post by oldelsieboy on Apr 29, 2021 18:58:02 GMT 1
Do I have to rivet the rear reflector bracket on to the mudguard or can I bolt it? No you don't HAVE to rivet the bracket on, you can stick it on with chewing gum if you so please. OEB
Post by Yogi on Apr 29, 2021 19:18:24 GMT 1
Standard is riveted but use nuts and bolts if you want it’s your bike 🏍
Post by roblc350 on Apr 29, 2021 19:38:43 GMT 1
il 2nd that use a rivet or two..neater than a nut & bolt
jam911
Post by jam911 on Apr 29, 2021 20:04:15 GMT 1
Trying to get hold of a rivet gun and a couple of rivets ....
Post by dusty350 on Apr 29, 2021 20:16:05 GMT 1
I've used stainless button head hex bolts in the past - look quite neat Dusty
Post by steven on Apr 29, 2021 22:18:39 GMT 1
I used stainless cap screws and stainless dome nuts.
Post by donkeychomp on Apr 29, 2021 22:28:06 GMT 1
Get a little stick on one and put it on the number plate.
Post by rigga on Apr 30, 2021 11:01:13 GMT 1
Get a little stick on one and put it on the number plate. Alex Same as mine, but depends if you're after an original style of placement.
Post by geoffers997 on May 1, 2021 8:16:02 GMT 1
I got a reflector and bracket off of Norbo then bought a cheap pop rivet gun to mount it. I thought I was being dead clever by colouring the rivet heads in with an olive green sharpie.....ok I'll get me coat.....
jam911
Post by jam911 on May 1, 2021 17:56:23 GMT 1
I am trying to source a rivet gun and a couple of rivets from friend and neighbours as I am not going to pay £30 + for a gun and 2 rivets from Screwfix
Post by risolc on May 1, 2021 18:13:21 GMT 1
£8 at wilko Still dear for 2 rivets
busby
RD 350 4l0
Post by busby on May 5, 2021 17:36:53 GMT 1
Hi everyone, as an aside to this how does norbo,s bracket fit. Is it on the front edge of the mudguard or does it fit behind. I can’t find a pic anywhere.
Post by geoffers997 on May 5, 2021 20:15:32 GMT 1
I put mine behind the mudguard so you’ve just got the two rivet heads showing on the front side
Post by JonW on May 6, 2021 2:09:17 GMT 1
Thats how its meant to be fitted on the ypvs
busby
RD 350 4l0
Post by busby on May 6, 2021 17:47:56 GMT 1
Many thanks for that
jam911
Post by jam911 on May 7, 2021 16:35:34 GMT 1
Got some small nuts and bolts to attache the reflector and they are too big...jeez this is turning into a saga...
Got builders at work next week so I will see if they have a rivet gun I can borrow
Post by donkeychomp on May 7, 2021 21:23:09 GMT 1
Mate, you're gonna need lots of nuts and bolts and washers. Buy them in assorted sizes and in bulk, you'll save a fortune in the long run!
jam911
Post by jam911 on May 14, 2021 18:12:57 GMT 1
Riveted on looks great...pics to follow
