Post by 1601pete on Apr 25, 2021 21:59:22 GMT 1
Evening all
Can anyone indicate what the symptoms are if a labyrinth seal fails please.
Thanks
Post by steeley on Apr 25, 2021 22:03:37 GMT 1
Evening all Can anyone indicate what the symptoms are if a labyrinth seal fails please. Thanks Hmmm , what are you talking about and what machine .
Post by 1601pete on Apr 25, 2021 22:09:11 GMT 1
The seal on the crank shaft in between a twin cylinder two stroke engine.
Post by steeley on Apr 25, 2021 22:34:35 GMT 1
What machine . LC /YPVS / RGV / KR1S /TZR / GT /RD /any clue . No
Post by chrisg on Apr 25, 2021 22:53:17 GMT 1
I've not heard of them failing. There usually replaced when the crank is refurbished. Why do you ask? Low down on power?
Post by 1601pete on Apr 25, 2021 23:19:56 GMT 1
Got issues on my 500lc. Can’t get a consistent air fuel ratio on the dyno on the front cylinders. Tried everything to eliminate.
Post by 4l04ever on Apr 26, 2021 0:09:56 GMT 1
Could be an air leak...
Post by tacky1 on Apr 26, 2021 2:32:00 GMT 1
Ive never heard of a labyrinth seal failing, Its a non contact seal. Did you do a leakdown test, Did you replace the crank seals, pistons etc, Could be a leaky head gasket, cylinder base gasket, crankcase leak or a crank seal leak, More info needed......;.;
Post by zed1015 on Apr 26, 2021 8:17:56 GMT 1
As above. Labyrinth seals are non contact and use opposing primary crankcase compression to prevent loss or transference of pressure between cylinders.. They run close to the crank but do not touch so there should be no physical wear unless there has been a previous engine or bearing failure where debris has entered the seal allowing intermediate material to contact the surfaces and increase the clearance which would reduce it's effectiveness.
Post by steeley on Apr 26, 2021 8:26:23 GMT 1
Years ago i heard of a 350 ypvs running badly and low on power. The chap i know who was looking into it tried all sorts to get to the bottom of it . In the end it was engine out and stripped .The owner had a fresh crank fitted a couple of weeks before and it turned out the new labrinth seal was under size .Once sorted all was well.
Post by midlifecrisisrd on Apr 26, 2021 10:40:10 GMT 1
Have only heard of one issue
It's basically a resistance. "Seal has a few discs. Some attached to the centre, some to the outer. Relies on the restriction of air having to work it's way through the "labyrinth"
As said only heard of one engine that wouldn't run correctly until it was replaced.
Now whether something else was accidentally fixed at the same time I don't know but it was a reputable builder who had tried everything else
Post by 1601pete on Apr 26, 2021 15:46:19 GMT 1
Ive never heard of a labyrinth seal failing, Its a non contact seal. Did you do a leakdown test, Did you replace the crank seals, pistons etc, Could be a leaky head gasket, cylinder base gasket, crankcase leak or a crank seal leak, More info needed......;.; Yeah, have conducted a leak down test which was all good and checked every other possible issue ref air leaks. Have access to spare coils, CDI, stator. All made no difference.
Post by 4l04ever on Feb 4, 2024 12:31:38 GMT 1
Did this issue get resolved?
