Post by marrcel on Apr 16, 2021 7:25:10 GMT 1
Hello smokers Yesterday i got a warning for noise on the new track of Zandvoort. I can’t check if packing is still OK after 6000km because the cans are poprevited. Any advice? Cheers Marcel
Post by hoist1 on Apr 16, 2021 7:41:27 GMT 1
Drill out and re-rivet. Rivet guns are cheap.
Post by stusco on Apr 16, 2021 7:47:20 GMT 1
In my experience packing never lasts very long, if your using it for track days probably best repack before every one 6000km is a lot ill bet theres nowt in there
Post by abar121 on Apr 16, 2021 8:08:05 GMT 1
Find out where the noise meters are and short shift there.
Post by marrcel on Apr 16, 2021 14:38:28 GMT 1
Today i received a reply from the manufacturer
Hi Marcel!
Your fiberglass be perfect, I assure. With 10.000 km, the fiber glass may be soaked in oil and, the noise increase a bit but... if you it change, I think not it improves
a lot. The fiberglass you should change 20.000 - 30.000km but depend of the % oil that you use.
If you need reduce the noise, you will need more lenght and/or more silencers diameter but... this no run with the perfect performance with our pipes. More lenght
give you more rpm but less PAR
Other option would be install dbkiller at outlet pipes but only fit to straight outlet pipes and you have curved outlet pipes (the performance worsten also, more
in fact that more lenght and/or diameter)
Let me know if I can help you in any way.
Many thanks!
Un saludo/Best regards
Roberto Campo
GR exhaust systems
Post by midlifecrisisrd on Apr 16, 2021 14:48:04 GMT 1
In my experience the wadding is compressed/soaked within 1000 miles and it's a lot louder
I would not use a db killer as any restriction in the pipe diameter is likely to cause piston damage
You will need a longer silencer or the type with a circlip in the end so you can repack easily
Post by Tobyjugs on Apr 16, 2021 19:18:11 GMT 1
Hi Marcel this is the reason my silencers are so long. It sounds a bit crappy but they are good for the track. They way they are made it's really easy to repack them as well. Maybe have a chat with Piet about it.
Post by marrcel on Apr 16, 2021 22:48:56 GMT 1
Mmm repacking easy, circlips, longer muffler enlighten us. If you have pics of the parts. 👍 30 april is next session. I probably prepare the 750srad. Ps The pwk30’s with velocity stacks ran so well. Bumdyno said well over 70rwhp. 7plate clutch was not 100% coping. 😤
Post by midlifecrisisrd on Apr 17, 2021 10:53:02 GMT 1
Mmm repacking easy, circlips, longer muffler enlighten us. If you have pics of the parts. 👍 30 april is next session. I probably prepare the 750srad. Ps The pwk30’s with velocity stacks ran so well. Bumdyno said well over 70rwhp. 7plate clutch was not 100% coping. 😤 This is a silencer from my TR pipes by Dave Swarbrick Think he sells these for £110 a pair There is a big circlip on the end like the Allspeed/Gibson pipes so can be repacked easily The other thing he told me was that if I was going to use the bike on the road he would make the stinger 100mm longer so it would be fitted 100mm into the rear cone He said this would make them quieter as otherwise it will make my ears bleed Steve
Post by marrcel on Apr 17, 2021 20:58:16 GMT 1
Thanks for the info Steve👍
