Post by pigboy on Apr 4, 2021 14:05:35 GMT 1
Hi what size bolt holds the front brake pads in I’ve tried 5.5mm too big and 5mm too small ,
Post by stusco on Apr 4, 2021 14:59:26 GMT 1
On the fowlers drawing there is the securing bolt for the caliper or a pin for the pads,I wouldnt use just any old bolts on brakes I would get the correct ones to be on the safe side
Post by LC_BOTT on Apr 4, 2021 15:32:54 GMT 1
Don't think its a threaded bolt, just a pin with a hex type head, it's held in via a sneaky circlip hidden under the plastic pad cover, a bit hard to see as it's bent 90 degs as well. this is from memory, so could be completely wrong
Post by rich on Apr 4, 2021 16:34:33 GMT 1
Yep same as FZ750 there is an angled R clip inside the caliper that holds the pins in
Post by JonW on Apr 5, 2021 0:31:32 GMT 1
yep, same base sumitomo caliper as the early ypvs rear unit. pin, not a bolt.
Post by pigboy on Apr 5, 2021 6:05:10 GMT 1
Thanks will get them out today
Post by JonW on Apr 5, 2021 8:17:15 GMT 1
feel free to put up pics, you might well have some random other caliper of course
Post by stusco on Apr 5, 2021 10:07:26 GMT 1
Here is one from the rear brake from powerhouse Its a fiver there are others on their site maybe one will fit
Post by midlifecrisisrd on Apr 6, 2021 8:17:14 GMT 1
If like the early caliper more likely like these Steve
Post by pigboy on Apr 6, 2021 9:59:25 GMT 1
If like the early caliper more likely like these Steve Yes these are the correct ones
Post by pigboy on Apr 6, 2021 12:08:55 GMT 1
Here is one from the rear brake from powerhouse Its a fiver there are others on their site maybe one will fit That’s for the rear brake
Post by JonW on Apr 6, 2021 13:39:03 GMT 1
yep, cos the 500s rear is the same as the 85-on 250/350 fronts...
Post by midlifecrisisrd on Apr 6, 2021 14:03:28 GMT 1
If like the early caliper more likely like these Steve Yes these are the correct ones That's a screenshot from Norbo's sale page 👍 Steve
