Post by mattlon on Mar 15, 2021 23:14:55 GMT 1
Hi What are everyones thoughts on rear tyre size for the 4lo? thanks
Post by 4l04ever on Mar 15, 2021 23:39:53 GMT 1
Stick with standard sizes.
Post by yamman1066 on Mar 16, 2021 9:39:38 GMT 1
110/80-18 bt46 is the best
Post by chrisg on Mar 16, 2021 10:01:17 GMT 1
110/80-18 bt46 is the best Or Avon Roadriders 😃
Post by mattlon on Mar 16, 2021 14:00:02 GMT 1
How badly does it effect the handling? has anyone got experience of fitting a larger tyre ( thinking ypvs sizes? )
Post by 4l04ever on Mar 16, 2021 19:27:06 GMT 1
If you fit oversize tyres they look like a giant black donut, and have no actual benefit.
Post by skydemon on Mar 16, 2021 22:08:05 GMT 1
Standard sizes work best. Both bridgestones and Avon RoadRiders perform equally in my opinion however I think the Avon is a prettier tyre. I’m not anti-Bridgestone either all my diesels have them
Post by 4l04ever on Mar 16, 2021 22:37:56 GMT 1
From some professional reviews, the Bridgestones were slightly better for grip and the Avons were slightly harder and lasted a little longer. I don't do millions of miles and want the best grip, so went with Bridgestones. Never had them slip even on track days.
Post by chrisg on Mar 17, 2021 12:43:50 GMT 1
I think most modern tyres will out perform the original tyres we had "yester year". With all the R and D done on these bikes I think Mr Yamaha probably got the sizes correct, so no need to over-size. JMO.
Post by Tobyjugs on Mar 17, 2021 18:47:36 GMT 1
I've had the Bridgestone BT45'5 get too hot and start to slide playing with the tyre pressure didn't really help. It was a warm day. Most of the time they are better than my skills.
Post by chrisg on Mar 18, 2021 12:12:26 GMT 1
I've had the Bridgestone BT45'5 get too hot and start to slide playing with the tyre pressure didn't really help. It was a warm day. Most of the time they are better than my skills. Either go on a diet or slow down I'm sure you aware that handling is a complicated subject and its not just down to tyres.
Post by mattlon on Mar 18, 2021 12:23:00 GMT 1
well aware, what i really wanted to know is if anyone had put ypvs sizes on a lc and did it effect the handling?
Post by Tobyjugs on Mar 18, 2021 12:34:45 GMT 1
I've had the Bridgestone BT45'5 get too hot and start to slide playing with the tyre pressure didn't really help. It was a warm day. Most of the time they are better than my skills. Either go on a diet or slow down I'm sure you aware that handling is a complicated subject and its not just down to tyres. That was my thoughts with my fat arse on it, but with a young man riding it and on two separate occasions. Also without inner tubes fitted to help the tyres run cooler. I forgot to say only on the track in Cartegena and Mettet.
fabiostar
the older i get the faster i was.
Post by fabiostar on Mar 19, 2021 22:31:36 GMT 1
i had a 120(in new money) avon on the rear of mine, handled a bit strange, felt like the rear was falling into the corner, so tried one size down and it feels better now, tho the fatter tyre looked nicer but just didnt feel right.
Post by dougw on Jun 22, 2022 21:07:29 GMT 1
I`ve started subjecting the 4L0 to Curborough Twisty Sprint.
So far my fastest time is 43 seconds.
The tyres have no time to warm up, I`ve got some spare wheels so want something really sticky, mileage not important !
43 seconds was set on newish BT46`s running 26 psi front and rear, and involved a small slide from the rear, so although some room to improve technique, more grip would be nice.
EBay Avon AM22 at £418 pair are a bit (lot) over my budget.
Any other recommendations and suppliers ?
Post by ringding on Jun 22, 2022 22:10:45 GMT 1
There was a dunlop combo which some used to run when I raced my 250. I had part worn 22/23s but tbh I think that was a mistake as the chatter was awful and they were oversize. The Dunlops were closer to stock size, race only compound, and the race winners used them from cold (barring the warm up lap). I'll see if I can dig out my old notes of you like.
Post by veg on Jun 22, 2022 22:56:55 GMT 1
Just do a search on Google I’ve just looked and priced pairs up for the avons all under £200 pr
Post by Tobyjugs on Jun 23, 2022 6:56:54 GMT 1
Heidenau K65 might be worth a try. It's the best tyre I've used up to now. They come in two different compounds.
Post by sp885 on Jun 23, 2022 8:24:26 GMT 1
What sort of mileage are you guys getting from your tyres?, I've had 2 sets of BT45's on my 350LC and got about 7,000km, or about 4,500 miles out of them, well the back one, the fronts still had a bit of life left in them but I always replaced them as a pair, last weekend I had a set of Roadriders MK2 fitted so I'll see how they go, I just use the standard sizes and run the front at 32 and the rear at 36 psi, the Avon's are hard to get here in Oz though, took 2 months to get them where I could have got the new BT46's straight away
Cheers Steve
Post by Robbieben on Jun 23, 2022 10:37:26 GMT 1
What sort of mileage are you guys getting from your tyres?, I've had 2 sets of BT45's on my 350LC and got about 7,000km, or about 4,500 miles out of them, well the back one, the fronts still had a bit of life left in them but I always replaced them as a pair, last weekend I had a set of Roadriders MK2 fitted so I'll see how they go, I just use the standard sizes and run the front at 32 and the rear at 36 psi, the Avon's are hard to get here in Oz though, took 2 months to get them where I could have got the new BT46's straight away Cheers Steve I've got Avon Roadrider 2's on my Gt750B and they are still like new after 2000 miles, I'm quite impressed with them TBH the BT45's weren't my favourite tyres, I really like the Avons.
Post by dougw on Jun 23, 2022 11:17:58 GMT 1
Just do a search on Google I’ve just looked and priced pairs up for the avons all under £200 pr AM22 ?
Post by yamman1066 on Jun 23, 2022 12:30:40 GMT 1
bt46 now
Post by chrisg on Jun 23, 2022 15:58:21 GMT 1
Just do a search on Google I’ve just looked and priced pairs up for the avons all under £200 pr Norbo stocks both avon and mitchelin
