jimmyg
Post by jimmyg on Mar 5, 2021 17:23:59 GMT 1
Hello all, I have just bought a ypvs hybrid project and I thought I would share my new adventure i bought it with out being able to view in person and had it delivered by kopite i knew there were a few issues and I have found a few more, and i will undoubtedly ask a thousand questions 1st pic As it turned up As it is now
Post by Mr Kipling on Mar 5, 2021 17:59:54 GMT 1
Look like a reasonable bike too start with...
Post by midlifecrisisrd on Mar 5, 2021 18:38:30 GMT 1
Looks good 👍
It's a 35 year old 2 stroke, it will always need something done 😀
Post by abar121 on Mar 5, 2021 18:40:14 GMT 1
That's lovely, enjoy!
Post by mouse on Mar 5, 2021 18:40:21 GMT 1
I like that!
Mouse
Post by arrdy350 on Mar 5, 2021 18:45:55 GMT 1
Interesting Hybrid 👍
Post by dusty350 on Mar 5, 2021 19:05:57 GMT 1
Looks a great start Got the main, expensive bits already fitted Dusty
Post by beardy on Mar 5, 2021 19:14:52 GMT 1
Hopefully only minor issues and you’ll get to ride it soon 👍🏻
jimmyg
Post by jimmyg on Mar 5, 2021 20:41:41 GMT 1
I bought it knowing it needed work but as dusty says the heavy lifting had been done😃 New clutch going in tomorrow as the old one was stuck solid,Oil pump seal done as there was a fair amount of 2 stroke in the gearbox oil and the seal had popped out😗, replaced the water pump with a high flow one with new bearing and seal as I was in there, made a leak test kit today and checked that and it's all good 😁 So hopefully tomorrow I should be almost ready to get it running again Next up will be replacing the rear suspension linkage set up,when it turns up from nk.as the dogbones are made up of 2 bits roughly welded together 😬 And they rub the bottom of the spring platform, so I am not chancing them. After that it's fork rebuild as 1 has started leaking with some stiffer springs and change the top yoke to raise the handlebars Is it possible to keep the clipons by dropping the forks through the yokes on Will that drop the front to far?
jimmyg
Post by jimmyg on Mar 5, 2021 20:42:20 GMT 1
Oh and get rid of the twin lights 🤣
Post by dusty350 on Mar 5, 2021 20:48:45 GMT 1
You can buy generic raised clip ons. They fit below the top yoke but are cast so they are raised an inch; 20200502_145900 by dusty miller, on Flickr Look at 50mm clip ons on ebay Dusty
jimmyg
Post by jimmyg on Mar 5, 2021 21:51:13 GMT 1
I'm not sure that will be enough of a rise for my back 😔 It's come with a modified top yoke but the risers don't look tall enough to clear the fork tops
Post by dusty350 on Mar 5, 2021 21:58:54 GMT 1
You could fit risers to the top yoke for normal bars. Downside is you may have to change cables and brake lines if they then aren't long enough Dusty
jimmyg
Post by jimmyg on Mar 13, 2021 23:15:25 GMT 1
New ebc clutch kit now fitted,and side case back on with high flow pump and seals all replaced, I then moved to fitting the nk rear linkage kit and that's when it started to go wrong 😔 Found the rear wheel spindle loose but didn't think to much about it till I got the wheel out and found the sprocket carrier spacer missing 🙄 So the rear bearings are stuffed,Got the swingarm out to find the lower mounting has had the nuts ground off, so new spacers need making to make the nk kit fit, 😕the lower linkage bush has been replaced with one with the wrong length so can never have pivoted ,just been sandwiched by the bushes, the top shock mounting was the same, god knows how it had any suspension on the rear So I'm now on hold till the new bushes turn up from fowlers and the local engineer makes some for the mounting plates For the time being I have cleaned the carbs out ready (found the air box broken so that needs replacing) fitted my new silicon hose set that look standard to make it fell like I am marketing some progress I will be checking everything on this bike now as I don't trust a thing on it
jimmyg
Post by jimmyg on Mar 14, 2021 0:49:23 GMT 1
Oh and the tiebars are missing, thankfully found some on here
Post by coops18 on Mar 14, 2021 13:55:27 GMT 1
Good luck with your new adventure, looks ok for a starting point .
jimmyg
Post by jimmyg on Mar 14, 2021 18:58:43 GMT 1
Cheers coops18 Fingers crossed I don't find too much more wrong
jimmyg
Post by jimmyg on Mar 20, 2021 23:05:33 GMT 1
Well the spacers are made and ready But still waiting for the bearing sleeve and sprocket carrier bush from Fowler’s, as after taking the order and money they email me to say they were short on both parts so had to order from factory. 😤 So I have swapped the neutral switch cover over Other than that I have had a airbox turn up with the top 2 pieces broken, but the seller sent out another pair the next day so can’t complain about his service, and been to the local bearing supplier for rear wheel/sprocket carrier bearings and seals. Just stuck waiting to be able to get the swinging arm in and back on its wheels so I can move to the front
Post by philmill on Mar 21, 2021 6:29:17 GMT 1
Looks like you'll have a great bike when you've finished, as you say, just check it all now. I hope you dont find too much wrong.
Phil
jimmyg
Post by jimmyg on Mar 21, 2021 20:18:52 GMT 1
Cheers Phil Fingers crossed I don't find much more
jimmyg
Post by jimmyg on Mar 28, 2021 20:59:20 GMT 1
Well the bearing sleeve and sprocket carrier spacer turned up Annoying how 2 things so small can hold you up So fitted the rear wheel bearings/sprocket carrier bearing and the seals, got the swinging arm and linkage back in, then found the swinging arm now hits the rear master cylinder outlet pipe and the under seat under tray(may have always hit but there are no bad markings), so I took the master cylinder off to find half a split pin used to attach the cylinder linkage to pedal And at that point I called it a night
Post by 4l04ever on Mar 29, 2021 8:34:24 GMT 1
Looking good so far. Lots of little issues to keep you busy :-)
Post by midlifecrisisrd on Mar 29, 2021 8:45:51 GMT 1
Standard stuff on a hybrid lol
Yes you will need to trim the part of the inner muddy below the frame rail
4mm spacers under the master cylinder mounts should sort that
All the fun of a hybrid, at least it will be done right now 👍
Post by midlifecrisisrd on Mar 29, 2021 8:48:53 GMT 1
jimmyg
Post by jimmyg on Mar 30, 2021 7:41:46 GMT 1
Cheers Guys, do I need to space the foot peg hanger as well?
jimmyg
Post by jimmyg on Mar 30, 2021 7:45:23 GMT 1
That's a handy link,Thanks Steve
jimmyg
Post by jimmyg on Apr 5, 2021 22:37:01 GMT 1
I haven’t been able to do much this week due to my back playing up ☹️, managed to trim the under seat tray so the swinging arm now clears, and ordered loads more parts 😁 As I had the rear brake assembly off and on the bench I thought I would rebuild the cylinder and bleed it there, rear caliper pistons are all free and moving smoothly 😳 so that’s ready to go back on when possible. I managed to get one front caliper off to check what’s draging on the front and to my surprise it appears to be the pads rusted solid in the anti rattle shims, the pistons look good and appear free, so when I can I will check the other side and I may have got lucky at last
Post by arrow on Apr 5, 2021 22:59:08 GMT 1
Looks like a really nice bike. Enjoy.
jimmyg
Post by jimmyg on May 2, 2021 10:17:32 GMT 1
Been a while since my last update, not massive progress had happened but it’s starting to gain pace again Rear suspension is all in only need to find a location for the shock remote reservoir, either on the left behind the panel Or on the right hand side of the frame, what have others done? The rear brakes are sorted and back on with new Ebc pads,but sadly one front caliper has sticky pistons so I have a rebuild kit here ready Forks are currently out I have rebuilt one with new seals and bushes and fitted uprated hyperpro springs and oil, just the other one to do when I can get the time
avb
andys vapour blasting
Post by avb on May 2, 2021 15:53:16 GMT 1
Not the best angle fitted above the lift handle frame rail
