Post by jimblob on Jan 14, 2021 16:00:55 GMT 1
Hi Guys & Gals, My cases are apart and almost ready for vapour blasting but there is some damage to the bracket that the end of the clutch cable is bolted to. Is this something I can repair myself with liquid metal as its not structural or would it need professional repair due to having them vapour blasted and the repair being visible. CEB85087-3829-4639-ADA0-D6F7DCD69D9C by James Smith, on Flickr Also with all this lock down, etc is it a bit risky to send cases through the post to have work done or would you not risk it and wait until after lockdown whenever that will be!! I'm in Derby in the East Midlands. Cheers, Jim
Post by midlifecrisisrd on Jan 14, 2021 16:24:07 GMT 1
You could make a bracket to mount to the case along with the cable retaining bracket but personally I'd get a bit an alloy weld repair done
I've posted cases no problem
Usually use UPS via Interparcel and never had an issue
Post by jimblob on Jan 14, 2021 21:50:37 GMT 1
Thanks Steve
I’ll have a search on here for alloy repairers 👍
Post by dusty350 on Jan 15, 2021 8:06:30 GMT 1
You could ask Garry at Metmachex. He's in Alfreton. He knows a thing or two about welding alloy !! Dusty
Post by Shytalk on Jan 15, 2021 8:55:06 GMT 1
Drill it, put a small metal post in there and then make a mould around it with plasticine then fill it with JB Weld, when it’s set remove the mould and file to the correct shape, works a treat and doesn’t cost much, plus if it doesn’t work then you’ll still be able to go down the welding route, but that too would still require a bit of tidying up afterwards too.
Post by headcoats on Jan 15, 2021 10:28:47 GMT 1
Post by bare on Jan 15, 2021 19:44:33 GMT 1
Suggest having it welded :-) Then you can use a later model Yama Clutch cable. Ones with a threaded mount at either end.. and lose the foolish Yama spring thing 'hold' down.
Post by 123 on Jan 15, 2021 22:17:44 GMT 1
watching with interest some great info
Post by jimblob on Jan 16, 2021 15:43:57 GMT 1
Thanks for the suggestions guys. I might just play safe and send it somewhere to be welded.
Cheers
Jim
