aj5764
Post by aj5764 on Jan 9, 2021 16:14:48 GMT 1
Good afternoon everybody I need help on my 250 LC brackets setting correct spacing between top and bottom yolks . As the 350 has space bars on the bottom of their brackets to help and was just asking if anybody could measure the length of these bars . Thanks for help and take care out there . Andy .
Post by steven on Jan 9, 2021 17:27:07 GMT 1
Hi Andy, Just measured a set. 45 mm is the length. Steven.
Post by shaunthe2nd on Jan 9, 2021 17:42:04 GMT 1
Both 250 and 350 brackets usually have the spacer arms but often broken off. The 250 LH one has an extra nut welded in to support the single horn bracket.
Post by steven on Jan 9, 2021 18:11:44 GMT 1
Both 250 and 350 brackets usually have the spacer arms but often broken off. The 250 LH one has an extra nut welded in to support the single horn bracket. As above. It was a 250 LH one I measured. I also have a few with the spacer arms missing. Steven.
Post by wallcraft on Jan 9, 2021 18:29:11 GMT 1
Both 250 and 350 brackets usually have the spacer arms but often broken off. The 250 LH one has an extra nut welded in to support the single horn bracket. As above. It was a 250 LH one I measured. I also have a few with the spacer arms missing. Steven. Got a spare right hand one to sell ?
aj5764
Post by aj5764 on Jan 9, 2021 18:57:04 GMT 1
Cheers Steven Much appreciated .
Post by steven on Jan 9, 2021 19:10:09 GMT 1
As above. It was a 250 LH one I measured. I also have a few with the spacer arms missing. Steven. Got a spare right hand one to sell ? Hi there, sorry, no, I dont have a spare one for sale. cheers, Steven.
Post by oldelsieboy on Jan 9, 2021 19:19:17 GMT 1
The distance from the bottom edge of the headlamp bracket to the top of the bottom yoke is 58mm. OEB
