Post by arrdy350 on Dec 29, 2020 17:37:29 GMT 1
Hi I am rebuilding my 350 YPVS engine and I just want to check will Castrol Power 1 SAE 10W-30 4T oil be ok to use? It is HC synthese motor oil does this mean it is fully synthetic? But it does not say this on the bottle.
Thanks
Post by Chewie01 on Dec 29, 2020 18:13:36 GMT 1
Post by midlifecrisisrd on Dec 29, 2020 18:31:41 GMT 1
Exol 10/40
£20 for 5l delivered 😁
Post by arrdy350 on Dec 29, 2020 18:34:17 GMT 1
The oil is for a motorbike. But the oil I have does not say it is fully synthetic or semi synthetic. I have heard that fully synthectic is not good for wet clutchs. It sayes in the manual 10W-30 oil is what to use.
dezcbr
Post by dezcbr on Dec 29, 2020 18:35:32 GMT 1
After struggling to select neutral with the engine running I put Silkolene light gear oil in my power valve, I can now select neutral, therefore I highly recommend
Post by stusco on Dec 29, 2020 18:37:17 GMT 1
The oil is for a motorbike. But the oil I have does not say it is fully synthetic or semi synthetic. I have heard that fully synthectic is not good for wet clutchs. It sayes in the manual 10W-30 oil is what to use. If it doesn’t say suitable for wet clutches dont use it
Post by arrdy350 on Dec 29, 2020 19:19:42 GMT 1
Thanks for the replies 👍 I will buy some different oil. My dad can use it in his bike 😃
Post by midlifecrisisrd on Dec 29, 2020 19:48:00 GMT 1
If it says it is for motorcycles it will be wet clutch suitable
Post by liffy16 on Dec 29, 2020 20:02:00 GMT 1
Must admit I tend to use whatever oil I have left over from my cars,should use bike specific I know!!
Post by copper99 on Dec 29, 2020 20:10:28 GMT 1
Must admit I tend to use whatever oil I have left over from my cars,should use bike specific I know!! Ive done this as well, never an issue with it. My LC at the moment has BMW 4 stroke bike oil in the gearbox , reason being my friend works for BMW , its free and was on the shelf ...another friend of mine refused to pay bike oil prices & run all his ( 4 stroke ) bikes on car oil for years, he did use them hard , home and abroad , never a problem. That said, i did need some gearbox oil today for the YSR and opted for the more usual halfords gear oil.
Post by pdxjim on Dec 29, 2020 20:43:45 GMT 1
Rotella!
Post by rigga on Dec 30, 2020 0:19:24 GMT 1
ATF220 from work that we use in transmissions on the diesel trains, wet Clutch compatible, and free, lovely.
Post by mak595 on Dec 31, 2020 11:37:51 GMT 1
Silkoline (or any) light gear oil for me
Post by lcmarky on Dec 31, 2020 12:01:13 GMT 1
After struggling to select neutral with the engine running I put Silkolene light gear oil in my power valve, I can now select neutral, therefore I highly recommend Silkolene Light for me too.
Post by looey on Dec 31, 2020 12:28:29 GMT 1
If it's an engine oil, simply check if it has a JASO MA Spec, that means it's designed for Motorcycles with Wet Clutches.
Post by mangocrazy on Jan 3, 2021 21:07:08 GMT 1
Just wondering if anyone has used this motorcycle gear box oil? I'm currently using Silkolene Light Gear oil and seems fine.
Post by lc350pete on Jan 3, 2021 23:27:25 GMT 1
I’ve always used rockoil light gear oil had no issues
