Post by buck1963 on Dec 26, 2020 19:59:51 GMT 1
Does it make any difference if there gen yam or not?one of mine has snapped so I need to buy a set ,thanks
stasky
Post by stasky on Dec 26, 2020 20:32:26 GMT 1
ive used norbos coloured ones on many builds with no probs at all,they come in black,and there also available on yambits,
Post by JonW on Dec 26, 2020 22:40:21 GMT 1
Have a search on here, covered these cables a few times over the last year.
Post by Shytalk on Dec 27, 2020 11:18:04 GMT 1
As long as the inner cable and outer sleeve is the correct length then I don't think it matters which cable manufacturer you use, unlike some other cables. If the inner / outer is wrong you'll never get the valves adjusted correctly.
Post by rich on Dec 27, 2020 13:46:44 GMT 1
I actually made my own using mountain bike gear cables from Ebay, work out really cheap too. As above, as long as they can be adjusted within the required range they will be fine. The only tricky bit was making nipples the right size to fit the recesses in the valve pulley. I cut the plastic insulation off some electrical terminals and crimped them on.
Post by buck1963 on Dec 27, 2020 21:23:31 GMT 1
Thanks for the help folks
Post by lb on Dec 28, 2020 15:09:34 GMT 1
Id be looking into why they snapped.....
