stotty
Post by stotty on Dec 2, 2020 14:01:41 GMT 1
Hello all
Wondering if anyone used replacement fork tubes from Legend £150 pair? Just wonder how they compare to Norbo's at £230 pair?
Massive choices out there ref fork seals but wonder if you have any recommendations on pattern units as gen yam expensive?
Thanks fellas
Post by 29davyt on Dec 2, 2020 17:50:14 GMT 1
Post by tony2stroke on Dec 2, 2020 17:50:19 GMT 1
A lot of Legend stuff is cheap Chinese made rubbish, common thoughts are to get your standard ones re-chromed.
The owner of Legend has been on here and proved himself to be a ****
Post by veg on Dec 2, 2020 18:05:48 GMT 1
My thoughts are always wherever possible go genuine for seals and bearings they generally are more expensive but tend to be a known quality and quantity cheaper rarely hits the mark. I wouldn’t buy legend stuff as per Tony’s post parts that have a habit of not being fit for purpose and an owner that appears not to want to own it. Fork legs either rechrome or go Norbo. Norbo is an enthusiast who set this forum up his parts are used if they aren’t fit he won’t stock them so you’re buying from a fellow enthusiast with a known reputation.
Post by lcmarky on Dec 3, 2020 10:45:27 GMT 1
I'd say £230 for a pair of genuine fork tubes is pretty good & certainly not worth getting pattern parts for a whole load of reasons such as safety, reliability and longevity..
Fit once and forget.
Post by JonW on Dec 3, 2020 13:21:06 GMT 1
I doubt £230 would buy a pair of genuine fork legs would it? Norbos are 'non-Chinese' i think, but Im not sure they were claimed to be Gen Yam were they?
Ive used webike LC fork legs as they were the best value shipped to me when i needed a single leg. Japanese quality etc. Post to other parts of the world and import duties may change the price for you, for Aussie buyers webike is the smart option most likely.
Post by 29davyt on Dec 3, 2020 13:23:46 GMT 1
I'd say £230 for a pair of genuine fork tubes is pretty good & certainly not worth getting pattern parts for a whole load of reasons such as safety, reliability and longevity.. Fit once and forget. Originals £212.89 each from Fowler’s, don’t think Norbo’s are originals but a good replacement. Re-chrome originals seems to be way to go, as long as they are originals,, hmmmmm ?🧐
Post by lcmarky on Dec 3, 2020 21:47:23 GMT 1
I guess what I’m trying to say is the cheapest ain’t the best.
stotty
Post by stotty on Dec 6, 2020 10:44:55 GMT 1
Thanks fellas for taking the time to help out. I'm new on here so will def search out threads etc in future. Seems an overwhelming win for rechrome or Norbos. I spoke to him and his are italian made so probably TNK??
With the forks being conventional I think decent after market seals should be ok-i'm mulling it over..think ill go Norbos tubes and pattern seals etc
I'll post how i get on..
Thanks again
Post by veg on Dec 6, 2020 23:57:54 GMT 1
Get seals from Norbo do not buy any from yam bits 👍 If you’re replacing the seals and stanchions measure your springs to make sure they are in service tolerance and get new bushes . They are all unlikely to have been changed oh and if you’ve the drain bolts at the bottom of the legs all new washers.
stotty
Post by stotty on Dec 14, 2020 11:30:13 GMT 1
Thanks Veg
Post by JonW on Dec 14, 2020 22:49:46 GMT 1
I always buy OEM seals, but so long as your stanchions are not pitted and the seals are not dirty then you should get a seal even on something aftermarket.
Post by earthman on Dec 14, 2020 23:05:09 GMT 1
Get seals from Norbo do not buy any from yam bits 👍 If you’re replacing the seals and stanchions measure your springs to make sure they are in service tolerance and get new bushes . They are all unlikely to have been changed oh and if you’ve the drain bolts at the bottom of the legs all new washers. +1 on measuring the springs, I changed mine recently due to being under spec, fitted Hagon ones, certainly made a difference.
stotty
Post by stotty on Dec 20, 2020 21:14:54 GMT 1
TNK stantions arrived..pattern seals..rebuilt 1 tonight..used 10W 30 engine oil..just thought why not..they were engineered this way so will see how they do..😁
Post by stusco on Dec 20, 2020 21:36:58 GMT 1
Ive had Norbos stantions and seals for five years now no problems to report
