Post by shaunthe2nd on Dec 1, 2020 21:34:40 GMT 1
Anyone recognise what these parts are off/for? Came in box of bits with my 31k Project, but haven't worked out what they are for yet and don't want to dump them if they are important. Need to ID the single bit above the ruler, and the 6 cup type washers underneath. Thanks.
avb
andys vapour blasting
Post by avb on Dec 1, 2020 21:40:24 GMT 1
are they air cooled rd engine mounting parts
Post by shaunthe2nd on Dec 1, 2020 22:01:00 GMT 1
are they air cooled rd engine mounting parts The upper rubber bit as well?
avb
Post by avb on Dec 1, 2020 22:06:17 GMT 1
are they air cooled rd engine mounting parts The upper rubber bit as well? could be shot down by the experts but id say it is a rubber mounting for the engine
Post by chrisg on Dec 1, 2020 22:43:43 GMT 1
The upper rubber bit as well? could be shot down by the experts but id say it is a rubber mounting for the engine My thoughts, as they have a flat.
Post by shaunthe2nd on Dec 1, 2020 23:14:21 GMT 1
If they not for 31k then if anyone needs these then they are available for cost of post.
Post by 4l04ever on Dec 2, 2020 22:35:32 GMT 1
The top rubber looks like an engine mount damper rubber from an air cooled RD400, as the 250 was solid mounted.
Put up pics of the metal parts flipped over.
Post by dusty350 on Dec 3, 2020 21:49:53 GMT 1
Post by 4l04ever on Dec 4, 2020 19:19:07 GMT 1
The rubber one above the ruler looks like the short RD400 ones. Not sure about the washer bits below the ruler.
Post by shaunthe2nd on Dec 4, 2020 19:56:20 GMT 1
The top rubber looks like an engine mount damper rubber from an air cooled RD400, as the 250 was solid mounted. Put up pics of the metal parts flipped over. I was in garage today and forgot. It will be Monday before I get a chance to take another pic. Thanks for help.
Post by shaunthe2nd on Dec 27, 2020 23:07:44 GMT 1
The top rubber looks like an engine mount damper rubber from an air cooled RD400, as the 250 was solid mounted. Put up pics of the metal parts flipped over. Apologies for the delay, here's a pic showing both sides. These are not 4L0/4L1 and if not for my 31k build, then they are free to a good home if anyone can use them.
Post by kostas on Dec 28, 2020 8:17:11 GMT 1
The rubber mount looks identical to the Suzuki RGV engine mounts.
Kostas
