garee
Post by garee on Nov 22, 2020 16:22:23 GMT 1
Hi guys Hope all is well Are fuel tanks repairable if they have signs of rust inside ?? Many thanks in advance
Post by broughton on Nov 23, 2020 17:06:30 GMT 1
you can get kits to clean the rust and seal the tanks inside there are a few about not sure which ones are the best thou.
garee
Post by garee on Nov 23, 2020 21:49:53 GMT 1
Thanks pal Yes I’ve seen some that appear to be resin based I wonder if people have used these with success ? I guess so as tanks seem super duper rare !
jh002
Post by jh002 on Nov 23, 2020 23:18:50 GMT 1
I opened the bottom of a TZR3MA tank (rot) and found the sealer (resin I believe) had separated in 75% of the inside into flakes. I believe cleaning is the most important part of the process. If you have reasonable thickness of metal it might be better to explore alternatives. I had to blast the tank inside & the seams were a pig.
Post by Gunny on Nov 27, 2020 17:52:36 GMT 1
Depends if its surface rust inside or a hole thats leaking
jh002
Post by jh002 on Nov 27, 2020 18:07:53 GMT 1
Depends if its surface rust inside or a hole thats leaking Agreed, more info required but either way fill it with cleaning agent see what's there. Once the sealer is used there's no going back without surgery.
garee
Post by garee on Nov 27, 2020 19:10:11 GMT 1
Depends if its surface rust inside or a hole thats leaking Agreed, more info required but either way fill it with cleaning agent see what's there. Once the sealer is used there's no going back without surgery. Looks to be some surface rust inside on the centre ridge just below the fill hole if that makes sense
garee
Post by garee on Nov 27, 2020 19:11:13 GMT 1
Agreed, more info required but either way fill it with cleaning agent see what's there. Once the sealer is used there's no going back without surgery. Looks to be some surface rust inside on the centre ridge just below the fill hole if that makes sense What’s a good product for this guys please ?
Post by Gunny on Nov 27, 2020 19:15:11 GMT 1
Agreed, more info required but either way fill it with cleaning agent see what's there. Once the sealer is used there's no going back without surgery. Looks to be some surface rust inside on the centre ridge just below the fill hole if that makes sense Get yourself 16 bottles of white vinegar out of Aldi, fill the tank with it leave it in for a week shaking it up every couple of days. Empty it out, wash tank out with soapy water, or i powerwash mine, dry with a hairdryer (inside0 then coat with wd40 to stop flash rusting, I`ve done this 3 times and worked every time.
garee
Post by garee on Nov 27, 2020 19:27:37 GMT 1
Looks to be some surface rust inside on the centre ridge just below the fill hole if that makes sense What’s a good product for this guys please ? Ah ok mate Sounds easy enough Best to do this than use that epoxy type stuff which coats the inside. ? I guess once you coat it there’s no going back !!
Post by Gunny on Nov 27, 2020 19:34:14 GMT 1
If its not leaking why coat it ? try this method, you`ll be amazed
garee
Post by garee on Nov 27, 2020 19:38:32 GMT 1
Cheers pal Sounds good Much appreciated!! Whilst you’re there, is it possible to get an mph speedo face for a mk1 LC to replace the kmh one ? I didn’t really want to get into modifying the guts of the clocks if possible
jh002
Post by jh002 on Nov 27, 2020 19:46:34 GMT 1
I got mine with holes in the base so I was cutting it out anyway. But even if you have small holes lead load/ solder it. Empty tank while parked up over long periods you'll be back to rust again.
Post by museumman on Dec 23, 2020 17:11:54 GMT 1
I've sold quite a few tanks from Europe, but kicking myself now as need some myself The ethanol in the Unleaded fuel strips the zinc coat then starts to corrode. I bought bikes 15 years ago from Switzerland that mint tanks, so I reckon they'd been stored away before they used ethanol as an additive. I found a bike with the grey epoxy layer inside, they had cut a square out the bottom of the tank probably to help clean it out, rewelded it then lined it with epoxy. However when i got the bike it had peeled down and fuel would splash over the side inbetween the layers. It works, but you have to be very thorough and hope for a bit of luck.
I cleaned a tank with white vinegar then sealed the inevitable flash rust with Rust Remedy. I use a fuel stabilizer and hope for the best.
Post by guiri on Dec 23, 2020 20:50:16 GMT 1
I've sold quite a few tanks from Europe, but kicking myself now as need some myself The ethanol in the Unleaded fuel strips the zinc coat then starts to corrode. I bought bikes 15 years ago from Switzerland that mint tanks, so I reckon they'd been stored away before they used ethanol as an additive. I found a bike with the grey epoxy layer inside, they had cut a square out the bottom of the tank probably to help clean it out, rewelded it then lined it with epoxy. However when i got the bike it had peeled down and fuel would splash over the side inbetween the layers. It works, but you have to be very thorough and hope for a bit of luck. I cleaned a tank with white vinegar then sealed the inevitable flash rust with Rust Remedy. I use a fuel stabilizer and hope for the best.
I can spare a rust free rd125lc tank if you need one, As far as de rusting a tank you cant beat DEOX-C Makes it so easy. Regards John.
Post by museumman on Dec 23, 2020 22:27:41 GMT 1
Hi John, I think we just had a chat on FB
The last tank I tried was for a friends 250LC this July and I had ordered Deox-C for the first time (I also ordered some of their hand cleaner to make the most of the postage ) It was a lot quicker than white vinegar as you say, but this tank was so bad it needed two tries..... and then it holed It has put me off so I'll probably give up on rusty tanks and would welcome a PM from you with a price for one of your tanks.
The mistake I made with my friend's, was telling him the tank looked solid where I always see the RD125 ones hole (front right). And this 250 unexpectedly (for me) holed further back on the right side.
Regards Michael
garee
Post by garee on Dec 26, 2020 15:29:01 GMT 1
John I’d be interested in an LC tank if you have one please? I’ll message you Thanks Gary
Post by raven13 on Dec 26, 2020 18:28:36 GMT 1
We do at least 1 tank de-rust and liner a week on various bikes. The only product we ever used is flowliner. We always use bio rust first to remove any rust and etch the inside of the tank first. Preparation is the key to lining a tank and make sure when it comes to lining it make sure you give it 100% of your attention.
garee
Post by garee on Dec 28, 2020 20:49:24 GMT 1
I can spare a rust free rd125lc tank if you need one, As far as de rusting a tank you cant beat DEOX-C Makes it so easy. Regards John. Interested in a tank if you have one John 👍👍
garee
Post by garee on Jan 1, 2021 13:22:48 GMT 1
I can spare a rust free rd125lc tank if you need one, As far as de rusting a tank you cant beat DEOX-C Makes it so easy. Regards John. Interested in a tank if you have one John 👍👍 Yes please on the tank if you have one John ? Cheers Gary
garee
Post by garee on Jan 1, 2021 13:23:41 GMT 1
We do at least 1 tank de-rust and liner a week on various bikes. The only product we ever used is flowliner. We always use bio rust first to remove any rust and etch the inside of the tank first. Preparation is the key to lining a tank and make sure when it comes to lining it make sure you give it 100% of your attention. What’s the cost guys to do a 125 tank please ?
Post by raven13 on Jan 2, 2021 10:11:14 GMT 1
We do at least 1 tank de-rust and liner a week on various bikes. The only product we ever used is flowliner. We always use bio rust first to remove any rust and etch the inside of the tank first. Preparation is the key to lining a tank and make sure when it comes to lining it make sure you give it 100% of your attention. What’s the cost guys to do a 125 tank please ? we charge a minimum of 3 hrs labour plus materials.
