Post by julianboolean on Oct 7, 2020 20:40:15 GMT 1
The right hand switch gear on my 31K is f**ked, threads are knackered, it's cracked and was held onto the bar with a self tapper. So I need a complete throttle assembly, I don't need it to be original or have the light switch. So what's available, could I use a TZ assembly?
Post by headcoats on Oct 7, 2020 20:45:03 GMT 1
Could you use an LC one ?
Post by julianboolean on Oct 7, 2020 20:58:21 GMT 1
Yes I could use an LC one, carbs are the same diameter so the lift will be the same, had a look on eBay and there are loads of LC ones but no YPVS ones, weird because Yamaha made a lot more power valves than LCs
Post by midlifecrisisrd on Oct 7, 2020 21:03:11 GMT 1
Post by midlifecrisisrd on Oct 7, 2020 21:06:45 GMT 1
Post by julianboolean on Oct 7, 2020 21:15:38 GMT 1
I think I've got a Fireblade HRC quick action assembly in the shed, might see if I can get that to work.
Post by oldelsieboy on Oct 7, 2020 21:16:17 GMT 1
The right hand switch gear on my 31K is f**ked, threads are knackered, it's cracked and was held onto the bar with a self tapper. So I need a complete throttle assembly, I don't need it to be original or have the light switch. So what's available, could I use a TZ assembly? TZ350 throttle assembly is designed for twin cables & if you could find one you'll pay through the nose for it. OEB
Post by reedpete on Oct 7, 2020 22:11:30 GMT 1
Maybe one off a 2Ma or FZR400 or something is an alternative
Post by peddrotzr on Oct 7, 2020 22:19:01 GMT 1
I fitted a Domino TZ twin pull throttle with Yamaha R6 switch gear.
Post by julianboolean on Oct 7, 2020 22:19:58 GMT 1
FZ750 (I've got one of those as well) looks very similar but is push/pull throttle, but could be made to work quite easily.
Post by rich on Oct 7, 2020 22:43:25 GMT 1
I have a Domino twin pull throttle on my LC and I made two single cables, one going to each carb but mine runs premix so no pump to worry about. KR1 throttle has a quick action and can be used with some fiddling.
Post by shaunthe2nd on Oct 8, 2020 10:52:10 GMT 1
The right hand switch gear on my 31K is f**ked, threads are knackered, it's cracked and was held onto the bar with a self tapper. So I need a complete throttle assembly, I don't need it to be original or have the light switch. So what's available, could I use a TZ assembly? I have a spare YPVS one, I think its an F2. I will send you pics in case its of interest.
