Post by daglad on Sept 12, 2020 13:53:05 GMT 1
You know when you have had a shite week at work and all you want to do is disappear into the man cave to play with your bike knowing that its just about finished and its about ready to roll. So today's objective was to go from front to back check then double check everything is tight and maybe just maybe have a little ride around the village (l live in the middle of nowhere) so not too worried about no MOT/Tax for a 5 minute ride. Brilliant all done, right i'm at it, lets go, ummm, why is the headlight on full beam? double umm it doesn't swith off, Hang on the indicators don't work either triple umm...........
So the headlight is sorted but the indicators well thats not so good. If l flick the switch l get nothing (both Indicators) but if l push and hold the switch they work but there is a delay and you can hear the electric servo clicking then they start but only if l hold the switch. Now l have noticed the oil and Neutral lights haven't come either.
l don't think its the electric servo l am thinking they either work or don't but could l try the one on my 92 firblade to try and eliminate it from the problem.
Could the Neutral and Oil light be connected?
Any thoughts on any issue would be very helpful. The frustrating thing is everything was working
Stuff it l'm going to play my guitar!!!!!!!!!
Post by flames on Sept 12, 2020 14:02:24 GMT 1
I'm not the only one who goes to play guitar when I need to calm down then. Could it be something simple like an earth issue?
Post by flames on Sept 12, 2020 14:04:45 GMT 1
I had similar issue with Indy's a while back, im sure I just wiggled all the connections and it eventually worked. Think it was the block connectors up front that sorted it in the end.
Post by daglad on Sept 12, 2020 14:54:49 GMT 1
Cheers flames, I know its going to be something simple but boy is it frustrating, its annoying because it was all working. Anyway the garage door is shut and the PRS is out
Post by kostas on Sept 13, 2020 6:58:16 GMT 1
I would check that the bulbs are the correct Watts per the manual.
Kostas
Post by Shytalk on Sept 13, 2020 9:15:45 GMT 1
Go through the connections, there aren’t that many, one will be dodgy, if they were previously fine and nothing else has been done , oh and check the battery’s okay too.
Post by JonW on Sept 13, 2020 9:21:05 GMT 1
must be connections if it worked prior.
often when just put back together and one works and the other is different its the earths in the switch imho.
