Post by museumman on Aug 17, 2020 14:12:52 GMT 1
I'm currently in Belgium so postage is £20 pounds ish (depending on size) for 10 kilos! Not too bad for many parts in the same purchase. I will dig out more parts to make it more worthwhile if I can.
No super rare stuff left like shocks, fairings or complete clocks Prices are on photo, contact me if you can't see them.
Both silencer cans have cut down perforated tube inside (the 1GU/x pipe has a regulator in main pipe so doesbt seem to affect running when theyre cut, just makes them noisier) , you can buy it on ebay if Norbo has none. It's only 3 spot welds to the nozzle.
I can sell the black silencer nozzle on its own for £15 ( I think they might be the same as TZR 250)
All parts are low mile undamaged unless stated (or obvious)
MK2-3 (belly pan has melting from am pipe but lugs are good) : Cylinder head no det marks and comes with temp sender and thermo)
MK1 (PIPE SOLD)
Pipe has a couple of dings but is solid. Down pipe and middle rear section need rubbing down to smooth.
Post by simon998 on Sept 9, 2020 22:19:33 GMT 1
Is the mk1 exhaust 10w or 12a?
Post by mellow on Sept 13, 2020 23:01:45 GMT 1
did matey off facebook not have the loom?
Post by museumman on Sept 20, 2020 11:14:38 GMT 1
did matey off facebook not have the loom? Not yet as he wanted to collect from MK, not to receive from Belgium
Post by museumman on Sept 20, 2020 11:15:21 GMT 1
Exhaust now sold (on this forum)
Post by museumman on Sept 20, 2020 11:17:01 GMT 1
It was a '46W' which is the same as 12A (removable baffle and small sleeve in downpipe) The 10Ws I get all have welded baffle .
Post by mellow on Sept 20, 2020 21:19:24 GMT 1
Can I have the clutch basket and centre?🙄
Post by brigitte on Sept 22, 2020 20:06:39 GMT 1
Exhaust now sold (on this forum) It has found a new home in Germany.
Regards
Brigitte
