Post by petehodges on Aug 9, 2020 15:11:39 GMT 1
Hi lads after your advice please Need to pull my finger out with this so what would you do with this problem with the chain Use white one or black one ? Stick it too the arm or screw it in ( I’m bit nervous about drill the arm ? Cheers 👍
Post by dusty350 on Aug 9, 2020 15:33:49 GMT 1
Why not make one that fits the arm exactly how you want it to ? A nylon chopping board from Lidl or Aldi is what I used. The generic black slider you have is a poor fit for the Lc swingarm and puts the bolt holes in the wrong place when you line the slider up with the chain run. This is what I did on the Café bike; 20190817_064549 by dusty miller, on Flickr I got my local engineers to drill and fit the Rivnuts in their lunch break, and it cost me a drink. Better than c**king it up myself, plus I don't have a Rivnut tool ! Dusty
Post by stusco on Aug 10, 2020 15:37:31 GMT 1
I used m3 double sided sticky tape that they use to fit widows in skyscrapers ,i got it from ebay its about 3mm thick and a clear gel
Post by veg on Aug 10, 2020 17:06:59 GMT 1
Nk altered my swing arm for my rs125 wheels he fitted a white nylon Slider at the same time on my build thread exactly as dusty says nylon chopping board. He fitted a threaded insert saves having the swing arm chewed up.
Post by veg on Aug 10, 2020 17:08:08 GMT 1
Stu sounds good. eBay?
Post by stusco on Aug 10, 2020 17:34:24 GMT 1
I got a sheet about the a4 size but its all used ive sent a couple of guys on some, with a piece of really hard nylon that i bought to make a slider, I used the rest to stick the mirrors back on to my audi😩 it was something like this www.ebay.co.uk/itm/233622072141
Post by veg on Aug 10, 2020 21:54:11 GMT 1
Looks good will get some.
Post by petehodges on Aug 10, 2020 22:14:05 GMT 1
thanks lads for coming back too me yes dusty I’ll try & make my own & get some tape of eBay , I also need too sort the chain guard out as there’s no fixing holes for that neither ,😡
Post by dusty350 on Aug 11, 2020 7:42:53 GMT 1
I know that when Dean ran the swingarm side of Metmachex, the chain guard mounts were an optional extra.
Dusty
Post by veg on Aug 11, 2020 8:40:03 GMT 1
I know that when Dean ran the swingarm side of Metmachex, the chain guard mounts were an optional extra. Dusty Really? Optional? I know he charged me £120 for the rear spindle. Thank god it’s been taken over.
Post by dusty350 on Aug 11, 2020 14:47:44 GMT 1
Everything was an optional extra with Dean ! Chain guard £25. Chain slipper £25 (still needed modding to fit properly !) Paddock stand bobbins £25. Slot chain adjusters as opposed to the eccentrics - £60 ! It was a good day when Garry and Tamsyn took it over Dusty
Post by zig on Aug 16, 2020 12:39:00 GMT 1
I used m3 double sided sticky tape that they use to fit widows in skyscrapers ,i got it from ebay its about 3mm thick and a clear gel what i used aswell....easy on and easy to replace when it gets a bit worn looking for no expense ZiG
