Post by andy748 on Jul 31, 2020 20:46:54 GMT 1
Hi Gents, i got these carbs off my wife's friend at work for a bargain price of £50, now they are marked 2GU? Which i surmise is Banshee, they are 28mm not 26 which is a bit strange, they haven't been bored out to 28mm and have no brass balls but a power jet instead? Question is, will they be any good on my valve engine? I will fit oil inlets to them. Thanks, Andy. IMG_3825 by Andrew Jolly, on Flickr IMG_3826 by Andrew Jolly, on Flickr IMG_3827 by Andrew Jolly, on Flickr
Post by rich on Aug 1, 2020 14:17:37 GMT 1
I can't see why not. The jet at the back is the main air jet, not power jet so looks like an improvement over the old 31K carbs. There is no vacuum take off for the fuel tap and as you said no oil inlets but they can always be added.
Post by andy748 on Aug 1, 2020 17:21:10 GMT 1
Thanks Rich, the vac take off isn't a problem as the RGV250 fuel tap fits straight on an Lc/Valve as that's what i will run with a single 8mm outlet. Andy.
