Post by jon on Jul 31, 2020 13:25:53 GMT 1
Hi all,
Has anyone got an accurate measurement of the thickness of a genuine YPVS gasket after it has been fitted and compressed?
Post by Shytalk on Jul 31, 2020 14:34:38 GMT 1
Hi all, Has anyone got an accurate measurement of the thickness of a genuine YPVS gasket after it has been fitted and compressed? Jon There's lots of gaskets to choose from...............assume you mean Head Gasket?
Post by jon on Jul 31, 2020 16:52:48 GMT 1
Yep, you guessed right. Little need to know any other I guess? Maybe cylinder base? In fact your right, how much is a squished base gasket too?
I’d like to know how far my squish is out pre assembly if possible?
Post by Tobyjugs on Jul 31, 2020 19:16:04 GMT 1
If you have the option mount an old genuine head gasket and fully torque it up and measure your squish. There will not be much difference. I have done this in the past multiple times with almost the same results. I think the maximum difference was 0.03-5mm. It's not enough to effect most builds unless you are trying to use a very small squish height.
Post by Tobyjugs on Jul 31, 2020 19:19:15 GMT 1
I forgot to add this is only with the LEAF type gaskets
