Post by roblc350 on Jul 28, 2020 14:11:22 GMT 1
YPVS 31K CYLINDER HEAD Engine was in the frame connected up the rad & pipework & filled with water water pissing out..Checked head bolts all were tight Engine taken out / head off / Head gasket looks new ( as this was surposed to be a rebuilt engine ) After reading some threads on here & talking to yogi brought some high temp silicone losened the base / barrel nuts to finger tight head face placed on pane of glass / no signs of any wrarpage silicone applied to head Torqued in sequence in 2 stages to final 22lb & tightened the base nuts Connected rad up on bench / filled with water Now Got Small constant WEEP WHAT WOULD YOU DO NOW ?? Thanks ALL
Post by midlifecrisisrd on Jul 28, 2020 14:45:22 GMT 1
Did you apply sealant to the barrel side of the gasket?
Post by roblc350 on Jul 28, 2020 16:18:01 GMT 1
Hi Steve as per the instrutions on the silicone apply to one surface only ? so i applied it to the head side
Post by veg on Jul 28, 2020 17:23:58 GMT 1
Rebuilt? By whom? Says who? When? Receipts?
Post by stusco on Jul 28, 2020 17:48:00 GMT 1
Hi Steve as per the instrutions on the silicone apply to one surface only ? so i applied it to the head side This would only apply if there wasn’t a gasket
Post by roblc350 on Jul 28, 2020 17:48:16 GMT 1
as i said veg surposed to of been rebuilt who said....the guy i brought it from by who...a engine builder / mechanic mate of his reciepts for parts fitted .... No Photos of rebuild...yes
Now back to the problem
Post by veg on Jul 28, 2020 17:53:25 GMT 1
So no comeback then? That’s what I was angling at. Eg builder of repute?
Post by roblc350 on Jul 28, 2020 17:58:13 GMT 1
No comeback...correct builder of repute...well i dont know him
Post by jon on Jul 28, 2020 18:02:46 GMT 1
I usually heat cycle a few time before putting any water in on a freshly installed gasket.
Post by tony2stroke on Jul 28, 2020 18:30:57 GMT 1
Get the head pressure tested, Check gaskets on bottom of barrels are clean, put a metal ruler (sideways) across the barrels once they are tightened down on engine, to check 1 is not higher than the other, I would do this first.
Post by roblc350 on Jul 28, 2020 19:19:41 GMT 1
i will try the metal ruler tip first as the head is off the base gaskets are new if above is good i shall apply silicone to both faces ( below & above the gasket and try again if that fails i shall replace the head or get it skimmed / refaced unless someone else has any other ideas
Cheers
Post by stusco on Jul 28, 2020 19:51:23 GMT 1
If your putting sealant on any gasket it needs to be on both sides of the gasket
Post by midlifecrisisrd on Jul 28, 2020 20:14:06 GMT 1
I also worry about between the layers when reusing a head gasket
Pity I'm bot at home, I'd have sent you a new pattern head gasket foc
Sure I have one somewhere
Post by roblc350 on Jul 28, 2020 20:30:06 GMT 1
Cheers Steve going to try what i said above tomorrow
Post by 4l04ever on Jul 28, 2020 22:08:42 GMT 1
Where was the water leaking from? Was it the same place after attempting repairs?
Post by Shytalk on Jul 29, 2020 9:52:19 GMT 1
Where was the water leaking from? Was it the same place after attempting repairs? Yes, my thought as well, where is it leaking from? any pictures of it that you can post up?
Post by earthman on Jul 29, 2020 11:31:33 GMT 1
I usually heat cycle a few time before putting any water in on a freshly installed gasket. Jon Interesting, I never would have thought of doing that on any water cooled engine,..how long does it take for the temp gauge to go up then? I'm guessing that you are just running the engine whilst in the garage rather than on the road??
Post by chrisg on Jul 29, 2020 12:22:30 GMT 1
I usually heat cycle a few time before putting any water in on a freshly installed gasket. Jon Interesting, I never would have thought of doing that on any water cooled engine,..how long does it take for the temp gauge to go up then? I'm guessing that you are just running the engine whilst in the garage rather than on the road?? I’m guessing that because the gauge isn’t in water, it will not read any temperature. I’m guessing it’s run for a couple of minutes? As you say, interesting 🤔
Post by roblc350 on Jul 29, 2020 14:10:43 GMT 1
Update Originally the leak was just down one side ( that was before I done anything) Also checked across the barrels with a metal ruler. & all ok there After applying silicone to just one side Of the head the leak was just towards the front corner Today siliconed both sides Head toqued down once again Going to let it cure overnight Can’t run the engine just yet as Dave the carb master has them So can check tomorrow on the bench to see if it’s now sorted or wait and run it up for a short time before adding water Think I’d rather know now if it’s sorted or not so will check tomorrow & if not get the head refaced Cheers
Post by tony2stroke on Jul 29, 2020 17:52:16 GMT 1
Head bolts and washers can cause some issues if not in good condition, if washers are bent or distorted they can alter the torque setting, also if the threads are not clean on the bolts or studs it can do the same, they should all tighten up with your fingers at same pressure until you start torquing them up, if you feel resistance there something wrong, always use some oil on the studs before torquing down and make sure everything is lubed up, dirt can also alter settings, if you hear any grinding when doing up bolts there is most likely some crud in there somewhere.
Post by Tobyjugs on Jul 29, 2020 17:54:08 GMT 1
Have you checked the height of both barrels? Base gasket landing face to cylinder head landing face.
Post by flames on Jul 29, 2020 18:22:06 GMT 1
I had same problem with mine leaking out of gasket on front corner area on l/h cylinder a while ago. Went through 3 gaskets ( fibre variety ) but had had them a while and eventually put it down to them losing the stickiness if that is the right term. I ended up getting a gen yam gasket and it seemed to cure it. I have removed the motor now and have noticed my barrels look to be sitting at slightly different heights. Not sure if barrels may not be a matched pair but maybe the cause of original leak. Perhaps the gen gasket just did a better job of sealing but may also of hidden an issue I didn't know I had.
