Post by philmill on Jul 24, 2020 15:11:07 GMT 1
Hi all, so having added the later electronic tacho on my 31k can somebody tell me which wire I need to connect the grey wire from the tacho to? My meme pry seems to think it’s the wire on the coil but thought I’d check before I do it! Thanks, Phil
Post by philmill on Jul 24, 2020 15:12:20 GMT 1
Hi all, so having added the later electronic tacho on my 31k can somebody tell me which wire I need to connect the grey wire from the tacho to? My meme pry seems to think it’s the wire on the coil but thought I’d check before I do it! Thanks, Phil Not sure where that typo came from... damn correcting text on my phone....
Post by philmill on Jul 24, 2020 15:18:05 GMT 1
Or is it one of these on the CDI?
Post by midlifecrisisrd on Jul 24, 2020 15:21:52 GMT 1
If it's a later ypvs tacho from a N/F/R then it's the black/yellow at the cdi or pv controller (it's the same wire going between the 2)
Post by philmill on Jul 24, 2020 15:23:33 GMT 1
Thanks Steve, so that not on that block? is it on the block coming up from the motor somewhere?
Phil
Post by philmill on Jul 24, 2020 15:26:05 GMT 1
Found it on the PV controller, thanks will try it now.
Post by foxyjohn on Jul 24, 2020 15:35:03 GMT 1
Make sure you have good battery Phil the N/F electronic tacho do's not work well with a tired battery
Post by philmill on Jul 24, 2020 16:05:05 GMT 1
Is there a way to test a tacho? mine appears not to work. Thanks for the info on the battery John, mine is a new battery so should be that causing the issue.
Phil
Post by midlifecrisisrd on Jul 24, 2020 16:21:45 GMT 1
Is it a black face tacho with red writing or a white writing with a speed warning light
The later rz250 ones used a pulse signal from the orange wire at the coil
Post by philmill on Jul 24, 2020 16:24:33 GMT 1
Black faced one Steve. Is there a way to test??
Phil
Post by midlifecrisisrd on Jul 24, 2020 17:14:42 GMT 1
Black faced one Steve. Is there a way to test?? Phil But what colour writing 😁 Hope I never sold you it 😬 Steve
Post by philmill on Jul 26, 2020 11:11:17 GMT 1
Its red writing, I cant remember if it the one from you Steve, I think not, that had a faded needle, I guess I'll be using it now though. I guess I'll be pulling the clocks off again today and swap the tacho, that way I'll know if its the tacho or the wiring....
Phil
Post by midlifecrisisrd on Jul 26, 2020 13:24:57 GMT 1
Yes, I remember it now. Was from Greece so sun faded
Post by philmill on Aug 3, 2020 10:34:57 GMT 1
Ok, sorry to be reviving this thread but having now tried 2 tachos and neither work so I need to find a way to either test the tacho or the supply?? cant see I have 2 that dont work....
Thanks, Phil
Post by midlifecrisisrd on Aug 3, 2020 12:08:07 GMT 1
Take the pv pulley cover off and rev the bike up
Pv's should start to move 5.5-6k
Fully open 9-10k
If the valves are operating then the signal is fine
Post by philmill on Aug 3, 2020 19:08:30 GMT 1
Thanks Steve, I'll try that this week, the PV seems to be cycling ok but will check that.
Phil
