Post by camman70 on Jul 19, 2020 19:54:05 GMT 1
I have a 10w carb which I had bought a few months ago and could never get it running good on the bike so after several strip down and clean I noticed that the hole in the rear where you look through to the needle jet from air filter end did not have a blanking ball in it but should it have ?
the bike runs very well and pulls all the way through to the redline but is a bit fluffy below 5000rpm.
i have 12a carb and a late ypvs carb but these both have the ball fitted so this is the problem
thanks for any feed back I receive
Post by tony2stroke on Jul 19, 2020 20:22:19 GMT 1
I have a 10w carb which I had bought a few months ago and could never get it running good on the bike so after several strip down and clean I noticed that the hole in the rear where you look through to the needle jet from air filter end did not have a blanking ball in it but should it have ? the bike runs very well and pulls all the way through to the redline but is a bit fluffy below 5000rpm. i have 12a carb and a late ypvs carb but these both have the ball fitted so this is the problem thanks for any feed back I receive A common mod back in the day was a Leda kit, different jetting and emulsion tube with ball taken out and new air corrector jet, no ball put back in, with that kit fibre, reeds, Micron exhaust, platinum plug and full fairing, transformed a standard restricted bike into a full power unrestricted bike, 105MPH with all that done. God only knows what has been done over the years to these bikes, restricted UK spec bikes were slow. I think 10W was unrestricted bike and 12A was restricted, or other way round, can't remember sorry. Restricted bikes were almost dead till 5000 Rpm then they took off like a scolded cat.
Post by camman70 on Jul 19, 2020 20:37:12 GMT 1
Thanks for the information I think maybe I will fit a ball and give it a go to see if it cleans up the low speed response but when running the 10w carb it pulls really well and if I fit the 12a carb but with the 10a jet size 155 it rides well low down but no power further up the revs.
Post by tony2stroke on Jul 19, 2020 20:51:44 GMT 1
Thanks for the information I think maybe I will fit a ball and give it a go to see if it cleans up the low speed response but when running the 10w carb it pulls really well and if I fit the 12a carb but with the 10a jet size 155 it rides well low down but no power further up the revs. You can't have it all ways, high top end and good low down, its only a 125 mate, its 1 or the other.
