stu73
Enter your message here...
Member is Online
Post by stu73 on Jul 19, 2020 12:33:47 GMT 1
Hi The problems when buying a bike in boxes Can anyone tell me the length of wheel spacer brake side The one on the sprocket side is 20mm , and I have another one the same 20mm I’m sure I read on here brake side is 24mm Therefore I may have two sprocket side spacers
stu73
Member is Online
Post by stu73 on Jul 19, 2020 14:13:56 GMT 1
Meant to say width really Also if mine is the wrong size has anyone got a spare one that they want to sell Thanks Stu
Post by alankelly on Jul 19, 2020 14:30:56 GMT 1
Measured mine 350lc and is about 24.5mm for the brake plate side
If nobody has a spare I can make you one in aluminium or stainless
25mm OD x 15mm ID x 24.5mm long
Best wishes Al
stu73
Member is Online
Post by stu73 on Jul 19, 2020 15:09:24 GMT 1
Thanks Al I will take you up on that offer , I will pm you
Post by jon on Jul 19, 2020 15:58:42 GMT 1
I’m no expert on standard LCs as both of mine are hybrids.
However I thought the rear wheel spacers were different between to 250 and 350?
Post by alankelly on Jul 19, 2020 16:06:41 GMT 1
Yes good point
I know the Cush drives are different but not sure about the two spacers ??
Hopefully some one will be able to confirm they are the same, or if they are different what the actual length is for a 250 brake plate side spacer.
Best wishes Al
Post by rich on Jul 19, 2020 19:06:57 GMT 1
Drum side is the same between 250 and 350, sprocket side is different
stu73
Member is Online
Post by stu73 on Jul 19, 2020 19:44:49 GMT 1
Thanks Rich
