Post by fatfreddy on Jul 18, 2020 0:11:29 GMT 1
Does anyone know if they fit a ypvs swingarm?
Post by rich on Jul 18, 2020 14:18:27 GMT 1
Fit as in drop straight in, or fit as can be made to fit?
I can guarantee it won't drop straight in. So it's a question of how much work you want to do. I think the 150 tyre should just about clear the chain but it will be tight. Other things to consider are chain alignment and difference in axle diameter. The YPVS runs a 15mm axle, I am guessing the Mito is probably 17 or 20mm so will either need sleeving down or the YPVS arm and adjusters opening out to the size of the Mito spindle. You will also need the Mito rear brake setup so also have to consider how the caliper mount is anchored to the arm.
Post by midlifecrisisrd on Jul 18, 2020 14:35:01 GMT 1
A quick eBay search says spindle is 20mm so yes you will need to reduce the wheel bearing ID or or machine out the swingarm spindle holes to 20mm if there is enough meat in them
Post by donkeychomp on Jul 18, 2020 21:20:52 GMT 1
They sure as hell don't fit an LC swinger, and I'd be surprised if a wheel with a 150 tyre would squeeze into a PV arm. A 140 might be a better option, As mentioned you'll need the brake caliper and mount too. Have you thought about using a Mito swingarm instead?
Post by marrcel on Jul 19, 2020 7:39:58 GMT 1
Post by fatfreddy on Jul 19, 2020 17:53:03 GMT 1
Thanks all. I am trying to find an XJR400 or SZR600 wheel but haven’t managed. Thought of a mito wheel as there seems to plenty of them about.
Post by midlifecrisisrd on Jul 19, 2020 18:14:55 GMT 1
Think there is a wrongly listed one on eBay but a bit pricey
I'll pm you a link
