kenelm
Aspiring owner.
Post by kenelm on Jul 12, 2020 22:54:12 GMT 1
Hi, Where does the loom earth to the frame on a 4l0? Cheers Ross
Post by shaunthe2nd on Jul 12, 2020 23:32:35 GMT 1
Just below the coil.
Post by rich on Jul 13, 2020 9:38:54 GMT 1
Does no harm at all to run a few extra ones, I ran an earth cable from the engine case up to the frame and also from the battery negative to the frame.
Post by lcmarky on Jul 13, 2020 17:01:09 GMT 1
I've just dry fitted the VAPE Power Dynamo to my LC and was surprised when I couldn't initially get the Neutral light lit up..
Double checked the wiring & not that it's complicated, but it turned out that even with the engine bolted into the frame (bottom end only) it was not earthed to the chassis and simply connecting the gear linkage earthed them together and bingo there was my neutral light.
Definitely add another earth or two..
Post by stusco on Jul 13, 2020 17:34:57 GMT 1
Does no harm at all to run a few extra ones, I ran an earth cable from the engine case up to the frame and also from the battery negative to the frame. Me too
Post by bare on Jul 13, 2020 19:59:41 GMT 1
A 'basic' and mandatory upgrade IMO Disassemble a Typ Yama Loom and you will find blackened and often destroyed Black /earth wires. Because Yama San decided to save a yen on Ground wire.
Post by steeley on Jul 13, 2020 20:48:30 GMT 1
Hi , i fitted extra earths to my lc and a rd250e i restored modified .I ran a wire from the engine tacho drive bolt to a bolt from the engine mounting plate . Plus i put some extra earths in the head lamp and in the tail section .
